Removing cam bearing from a YS DZ 160 Crankcase
I am in the middle of trying to remove a cam bearing from a DZ 160 Crankcase. Anyone got any suggestions how too! -
Peter
CA
RE: Removing cam bearing from a YS DZ 160 Crankcase
I usually warm the side of the crankcase with a blow torch, then tap it with a rubber mallet & it should come right out
Adrian
Adrian
ORIGINAL: PeterP
Peter
Peter
I grind a slot in a piece of 4mm steel wire the width of the cam inner race.
It looks like a square C.
Then I heat the crankcase in the oven to about 200 degrees F. Then hold the crankcase with a hot glove and insert the wire.
Pull out on the wire evenly as you go around the circle of the race...you dont want to get the bearing wedged in crooked.
Keep working it and it will come out but it's a hassle for sure.
Remove any plastic parts and the pump before heating.
Glad to see you back.
Good Luck.
Thanks Adrian and Dave,
Finally got the little sucker out geez what a struggle.
I have certainly learnt a lesson never to leave a perfectly running YS engine in a model for an extended period- in my case 6 years and then expect it to run.
Yes Dave it has been a while. I had a bit of a break to concentrate on my business and I finallymay get some time for myself to do a bit of flying. I have gone to the dark side and am in the process of getting an electric contra model up and running. I simply want to get some flying under my belt to try and get my fingers working again - best way is to get my old IC model flyingso I can enjoy my 12-15 minute flights before I have tosettle into 8 minute flights.
My havent things changed in 6 years - 2.4G radios, electric F3A planesOMG everyonespeaks a completely new lingoat the flying field. Screw drivers and spanners have been replaced with multimeters andsoldering irons.
What will the next 10 years hold?
Cheers,
Peter
i have found the easiest way to remove these bearings is to "shave" some candle wax into the bore of the bearing & useing the shank of a twist drill - (the size of the bore of the bearing ) compress the wax (lightly tap with a hammer) - shave some more wax & repeat the process. as you continue to repeat this process the bearing will be jacked out of the housing. i know this sounds silly but it does work !!!!! takes about 3 mins !!!
ORIGINAL: PeterP
Cheers,
Peter
Cheers,
Peter
The next is a hope more than a prediction: gasoline power. Right now there is only one (my experience) powerplant capable of everything F3A power demands. In ten years we may have multiple options and maybe a 4 cycle that hauls the mail like a YS175 on 30% nitro does
