Ys ignition plug
Ys ignition plug
HI all,
Just wondering if anyone has experienced failure of the YS ignition plug after only 10 flights.
My 175z cdi refused to rev at high throttle .....misfiring and not making power throttle back and run good below 3/4 throtle
Removed the ignition plug and noticed the top part detached from the main body.........this is the second time first plug 20 flights and second 10 flights
The plugs were both new and genuine YS parts.
Just wondering if a bad batch worked themselves into circulation or something else is causing these failures
regards
regards
I am fairly sure its the plug.
I replaced it with an older plug and no problem.... see how it goes
rgds
I think you are correct apareira it does look like a factory problem that maybe YAMADA are not aware of.
Its the second failure that I had with the YS plug.
rgds
Mavros
rgds
Mavros
He changed the provider I think, as with the new plug it does not happens, on mine the anode was also loose (rotate), on the new ones I have heard of any problems, the have to ridges in the ceramic.
Regards
Regards
