If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 16 of 16
  1. #1
    drac1's Avatar
    Join Date
    Jul 2008
    Romaine, Tasmania, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    YS 175CDI Stopping
    Hi All, I have a new 175 cdi that runs ok on the ground, but when flying the engine will quit when going into the first or second manouvre of the pattern.
    I have changed cdi box and spark plug (checked gap). The engine has only had 5 or 6 tanks of fuel through it.
    I previously had the 170 cdi fitted that ran well and i have not changed anything bar the engine. I have another model with a 175 and that runs ok. Both models are identical in set up.
    Any advice is greatly appreciated.
    Regards
    Scott
    "There's no such thing as too much power"
    Pitts Special Brotherhood #6
    Carl Goldberg Ultimate 10-300 Brotherhood #116
  2. #2
    Join Date
    Dec 2006
    DENHAM SPRINGS , LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: YS 175CDI Stopping
    Change your clunk
    Bryan
    CKAero.net Team YS, Futaba, cool power, Central hobbies, Hyde Mounts, contra, xtreme composites
  3. #3
    drac1's Avatar
    Join Date
    Jul 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Bryan,
    I am not using a clunk. I use the Tettra bladder tank. I have been using these tanks since flying the DZ140 and have never had a problem with engines quitting.
    Regards
    Scott
  4. #4
    Seems you have air in the tank, try the clunk the way your tank is right now, with the bladder and all, just put the foam clunk on the hose and give it a try as Bryan said.
    Regards
  5. #5
    vquick's Avatar
    Join Date
    Sep 2003
    Navarre,FL , FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have that problem before and the problem was the pump replaced diaphragm also the 2 springs and the 2 check valves
    USA Rep. www.Skyaviations.com
    USA Rep www.classicpattern.com
    Jet Central www.jetcentral.com.mx/
    Team Pilot for
    OPTIPOWER Batt.
    JETI Radio
    MKS servos
    Demon Cortex
    2010 2011 2012 2013 2014 D3 Advance Champion
  6. #6
    Join Date
    Dec 2006
    ToowoombaQLD, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I had an intermittent fault with the hall sensor in my 170cdi which drove me mad for weeks.
    It'd run like a train on the ground but start to miss and carry on on the downwind pass after takeoff. Most times it would stop, sometimes it would just tick over at idle. A new disk valve/sensor assembly fixed it up (after changing nearly everything else).
    Just add that to the list of reasons why a YS stops in flight along with the millions of others
  7. #7
    Does it sound like it's going lean?
    Perhaps to isolate any issue with the ignition module, could you put a glow plug in the motor to see if you can get through a complete flight?
    Ryan Smith
    Team JR | Thunder Power RC
    F3A Unlimited | Castle Creations
  8. #8
    drac1's Avatar
    Join Date
    Jul 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I also had the same backplate problem with my 170.
    Initially the 175 would only run nice at half throttle. It sounded lean at idle. I ran it on a glow plug and the engine ran perfectly. I changed the complete backplate assembly from my 170 onto the 175 and then it ran fine at full throttle. The idle was still a bit funny so today i changed the regulator from my 170 to the 175 and now it idles perfectly and will transition well to full power.
    Will idle at 1600rpm for a few minutes and then transition up to full power without any problems. Max rpm is 6900 on the APC 20.5 X 10PN. My other 175 will pull 7200 on the same set up, but that has more run time.
    I flew the complete pattern today without any hint of a problem. On completion of the pattern i was practising a couple of manouevres and the engine quit. I landed and did not switch anything off. I trtied to start it and it wouldn't fire. I run the Tech Aero IBEC and this is switched from the gear switch. I checked the output and it had 5.3 volts. OK. I switched the IBEC off and back on again. The engine started and ran perfectly. Hmmm. Even though i have already changed the ignition module when fault finding the initial problem, i will change it again and see how that goes.
    Thanks to all for your advice and feel free to give any more that may be of benefit. I will let you know how the ignition module change works out.
    Regards
    Scott
  9. #9
    Join Date
    May 2004
    Whippany, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Scott,
    I am wondering if a standard CDI from a Saito gas 4 stroke might not work. I doubt a 2 stroke CDI from RCXcl will work but Saito makes 4 stroke gas engines and obviously has figured out the CDI portion. Just a thought
    Regards,
    MattK
  10. #10
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There's nothing tricky about the YS ignition box as it fires every up-stroke (compression AND exhaust) just like a two stroke. I could say if 2 stroke vs 4 stroke ignition curves are very different though?? Yamaha in their wisdom fitted one coil to my parallel twin 250cc 2-stroke and it fires both plugs at the same time when one's near the top (the other's near the bottom).
    If you've had a 170cdi running fine for ages, a 175cdi running OK and having problems with the 2nd 175, then I'd be tempted to swap out the good running 175 with the one that's giving you trouble. This should isolate the problem to the motor itself and rule out power supply, cdi box and fuel.
    After that it's anyone's guess or a warranty job??
  11. #11
    drac1's Avatar
    Join Date
    Jul 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the input. I will try another cdi box first then change the engine out if that doesn't work.
    I have had no problems with the engine distributor if it comes down to a warranty issue.
  12. #12
    drac1's Avatar
    Join Date
    Jul 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Changed the cdi box last night. I had 6 flights this morning without any problems whatsoever. I am back to work tonight so when i get home next week i will change the regulator back to the original just to confirm that the reg. is OK.
    At the end of the day when the dust had settled, the problem came down to 2 things.
    1) The back plate assembly was faulty.
    2) The cdi box was faulty.
    The replacement (warranty) back plate assembly arrived today. I will call the distributor later to arrange a cdi box.
    Thanks to all for your advice. It was greatly appreciated. For me it's still a learning curve with these things when something is wrong.
    I will keep you informed if there are any further developments.
    Regards
    Scott
  13. #13
    drac1's Avatar
    Join Date
    Jul 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just thought i would give an update on how the 175 is going.
    Excellent after sales service from the Australian YS distributor Tates Toy World. Thanks Eddie.
    The back plate, ignition module and the fuel regulator was changed during the fault finding process from my 170, which resulted in the engine running perfectly.
    The back plate and ignition module were replaced under warranty and fitted to the 175 to confirm all is good. I also refitted the original regulator.
    I have since had 15 flights and the engine is still running perfectly, with no misfires whatsoever.
    Just what i expect from YS.
  14. #14
    Join Date
    Dec 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: drac1
    Regards
    Scott
    Ha, don't be fooled into believing that these motors can be learned.
    They are like women in that they start acting up for only two reasons
    #1 Something's wrong with it. (Not your fault but becomes your problem anyway)
    #2 You're doing something wrong. (Sometimes you can get away with a lot, sometimes not)
    Figuring out where the problem lies and how to fix it (in both cases) boils down to a combination of trial and error and dumb luck.....
  15. #15
    Join Date
    May 2004
    Whippany, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bjr_93tz
    Had a chuckle or two on these comments. Been together with the same woman for a life time (going on 40 years) but since I know practically nothing about them, it musta been dumb luck. My pop, God rest his soul, used to say" finding and getting a good woman to stay with you is like hitting the lottery". My pop was genius philosopher.....LOS
    Regards,
    MattK
  16. #16
    Join Date
    Apr 2005
    Qld, , AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bjr_93tz
    ORIGINAL: drac1
    Regards
    Scott
    That is just so true. That would be why I stopped using a YS. The random event generator seems to roll up stop or not idle so may times.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
