JR 3517 (non-mg) Output gear
My Feedback: (8)
Hi All,
I've got one 3517 servo w/plastic gears (bought accidentally). In an effort to set it up like the other two 3517s in my plane, I purchased a metal output gear w/ bearings attached. The nylon gear pops off the servo fairly easily, but leaves a bearing and what looks like another part behind, stuck to the shaft.
1) Will I be able to remove the remaining parts and replace w/ metal output gear?
2) When I put the nylon gear back on, it seems like I can fairly easily rotate it on the pot shaft (pot stays where it is, gear moves). Am I missing something?
