Audax F3A - new project for 2013
RE: Audax F3A - new project for 2013
In the end the mold plug was sprayed with a layer of white gelcoat. Please note that the nose of the model is much longer than needed so we can cut it later either straight for the contra drive, or angled for conventional single propeller setups that require right thrust.
My Feedback: (25)
Incredible, Alex. Very impressive processes utilized to design and manufacture a top-quality F3A machine. I love seeing top quality design and manufacturing to make a top-quality model. You should be very proud. I hope you find it flies extremely well.
Thanks Ryan, i hope you will enjoy the next updates as well. There's still a long way ahead of us, so for now we'll keep working on it and i'm sure we'll have reasons to be proud when the model is up in the air
Highfly3D, for me the pictures above show up without problems, but i experienced some problems viewing pictures in other threads. Maybe it's a temporary issue with the forum server.
Looks like the image upload is finally working, so i'll continue with the updates.
The white gelcoat was sanded smooth, but we weren't fully satisfied with the surface of the mold plug so we sprayed a second layer of grey gelcoat. This was carefully sanded with 1500 grit and water; the white gelcoat underneath shows up here and there but the surface had a very smooth, mirror-like appearance.
I attached a few pictures of the mold plug with and without the canopy. The canopy fitting was not done yet at the time these pictures was taken, so there's a visible gap between the canopy and fuselage.
#31
When the fuselage mold plug was finished, it was time to add the parting boards. These were laser-cut from MDF and they fit perfectly, confirming the accuracy of the mold plug shape.
Next we waxed the surfaces, sprayed the mold gelcoat (green) and added the fiberglass layers to build the first half of the fuselage mold.
#33
I attached a few pictures showing the completed fuselage mold.
We took the pictures immediately after opening it, so the surfaces are still dirty with wax. The next step will be polishing the molds and cutting the opening in the canopy area.
#34
For Facebook users, you can see the pictures in higher resolution in my photo album at the following link (you will need to go in fullscreen mode):
[link=https://www.facebook.com/media/set/?set=a.432293993521272.1073741825.100002220265252&type=1]Audax F3A photo album[/link]
#37
A few details about the fuselage construction:
We decided to use Airex C55 as the core material, because it's lighter, stiffer, and easier to work with than balsa.
First the molds were waxed and sprayed with white gelcoat. We used 80g (2.9oz) fiberglass cloth for the first layer, then added the yellow airex and the 160g (5.7oz) carbon cloth. The carbon was reinforced with an additional layer of 80g fiberglass, and the final layer was 25g (0.9oz) FG cloth covering the whole surface. In the end we vacuum bagged everything and put it in the oven until the epoxy resin was fully cured.
Pictures show the gelcoat sprayed in the mold and the fuselage lay-up after vacuum bagging.
#38
The first fuselage came out at 690g, which is not bad for the first attempt, especially considering that we don't need a chin cowl that adds up to the final weight. The nose needs to be cut shorter to fit the 82mm spinner and the canopy flange needs to be trimmed, so this will save quite a few grams.
Todd Schmidt was very kind to help us with a lot of useful advice and we also have a few ideas where we can save some weight, so i'm sure the next fuselages will be lighter.
Pictures of the first fuselage, fresh from the mold:
#41
With so many pattern contests for me last year and a lot of work on a full size glider for my friend, it wasn't possible to finish the model in 2013, but we made some progress since then so it's time to update this thread.
Having completed the fuselage, we moved on to the tail surfaces. The mold plugs for the stabs were machined from MDF, here you can see a few images i took during the milling process:
#42
We didn't took pictures during the stab mold construction, but the process is not different from the fuselage molds.
Pictures of the finished stab molds:
#43
The stab layup consists of a sheet of 1.2mm Airex as core material, sandwiched between 2 layers of 25g/m2 fiberglass. The internal structure looks like this:
It's maybe a little stronger than needed, so it will be simplified in the future to make it lighter.
#45
Wonderful work Alex!
Keep the pictures coming, it's a joy to see good work and craftsmanship. Beautiful lines on your design, I guess the airflow will be very straight (you know what I mean by "straight") on the fuselage.
Best regards
Alejandro
Best regards
Alejandro
#48
We built a few composite fuselages in the past but composite wings are a new experience for us. We only found very limited online material about this subject, so the only way to get it right was to build a pair of wings, see what comes out and adjust the manufacturing process accordingly.
The composite skins are made of 2mm Airex sandwiched between 2 layers of 50g/m2 fiberglass, with a strip of peel ply for the hinge line. Everything was vacuum bagged and put in the oven for curing at 60 deg C.
All the parts for the internal structure were laser cut; we used 3mm liteply for the ribs supporting the wingtube and 6mm balsa for the main spar. These parts were considered critical so they were carbon laminated, which added quite a bit of weight. We also added a few strips of unidirectional carbon between the main spar and the wing skins. All the other parts were made of 2.5mm balsa.
The internal structure alone was 140g, which made it clear from the start that this pair of wings were going to be heavy, but we decided to build them anyway and use them for testing.
A few images of the wing internal structure:
#50
Thanks Jason. There are many composite models using peel-ply, for example the ZN Line Integral and also the Spark if i remember correctly. Kevlar is also used but it's a lot more expensive and some say it may crack along the hinge line.
