Audax F3A - new project for 2013
Old 05-18-2015, 01:41 PM
  #101
fehringer
Hi Alex,
this is simply stunning - many thanks for sharing!
Best wishes,
Gerhard
Old 05-18-2015, 10:38 PM
  #102
Alex Voicu
Thank you Gerhard !
Old 05-27-2015, 11:30 PM
  #103
Alex Voicu
The stab tube sleeve was attached to the fuselage with epoxy and microbaloons. The stab key is made of 4mm diameter aluminium and passes through a carbon tube glued inside the fuselage so it can be replaced if necessary.
The wing tube sleeve attached to the fuselage:
Wing and stab root blocks sanded to fit the fuselage:
A few images of the finished wing:
ID:	2099133   Click image for larger version
ID:	2099134   Click image for larger version
ID:	2099135   Click image for larger version
ID:	2099136   Click image for larger version
ID:	2099137   Click image for larger version
ID:	2099138   Click image for larger version
ID:	2099139   Click image for larger version
ID:	2099141   Click image for larger version
ID:	2099142   Click image for larger version
ID:	2099143   Click image for larger version
ID:	2099144   Click image for larger version
ID:	2099145   Click image for larger version
ID:	2099146   Click image for larger version
Old 06-05-2015, 11:10 AM
  #104
Alex Voicu
Installing the wing incidence adjusters:
Marking and drilling the adjuster holes into the wing root rib:
Wings fitted:
Cutting the aileron servo slots:
ID:	2100667   Click image for larger version
ID:	2100668   Click image for larger version
ID:	2100669   Click image for larger version
ID:	2100670   Click image for larger version
ID:	2100671   Click image for larger version
ID:	2100672   Click image for larger version
ID:	2100676   Click image for larger version
ID:	2100678   Click image for larger version
ID:	2100679   Click image for larger version
ID:	2100680   Click image for larger version
ID:	2100681   Click image for larger version
Old 06-12-2015, 10:33 AM
  #105
Alex Voicu
Adding wood dowels at the ends of the stab tube:
Marking the location of the stab retaining screw:
Drilling and tapping the stab tube holes:
ID:	2102189   Click image for larger version
ID:	2102190   Click image for larger version
ID:	2102191   Click image for larger version
ID:	2102192   Click image for larger version
ID:	2102193   Click image for larger version
ID:	2102194   Click image for larger version
ID:	2102195   Click image for larger version
Old 06-12-2015, 11:06 AM
  #106
Alex Voicu
After some thinking i decided to give up on the idea of having the elevator servos hidden inside the stabs. The thickness of the nut, servo arm, spacer, ball link and the screw head are all adding up, so the slot required for the free movement of the linkage would be very wide. For me this defeats the purpose of having the servo hidden inside the stabs.
The other alternative would be to use a very long servo arm and small servo travels so the ball link doesn't interfere with the stab underside, but i didn't want to sacrifice servo resolution.
I decided to install the servos on the stab undersurface so i had to improvise something for the servo mounts. Too bad i didn't think this through from the start because it would save a lot of weight, probably around 15g for each stab.
ID:	2102198   Click image for larger version
ID:	2102199   Click image for larger version
ID:	2102200   Click image for larger version
ID:	2102201   Click image for larger version
ID:	2102202   Click image for larger version
ID:	2102203   Click image for larger version
Old 06-19-2015, 10:46 PM
  #107
Alex Voicu
Marking the location and cutting the slot for the elevator control horn:
Hinging the elevators:
Adding some light filler on the stab surfaces:
Filler sanded off, final stab weights before covering:
Hinging the ailerons:
Adding light filler to the wing surfaces:
Filler sanded off, final wing weights before covering:
ID:	2104124   Click image for larger version
ID:	2104125   Click image for larger version
ID:	2104126   Click image for larger version
ID:	2104127   Click image for larger version
ID:	2104128   Click image for larger version
ID:	2104129   Click image for larger version
ID:	2104130   Click image for larger version
ID:	2104132   Click image for larger version
ID:	2104133   Click image for larger version
ID:	2104134   Click image for larger version
ID:	2104135   Click image for larger version
ID:	2104136   Click image for larger version
ID:	2104137   Click image for larger version
Old 06-20-2015, 11:39 PM
  #108
Alex Voicu
Before film covering, i assembled the model and took a few pictures. I'm not sure the pictures can reveal the size of this thing, so here are a few dimensions of the model. The wing root chord is 580mm which i believe is larger than anything out there at the moment. The fuselage is quite tall at approx. 380mm in the the canopy area and the fin is 455 mm tall. In general it seems huge and i barely had enough space for assembly.
ID:	2104791   Click image for larger version
Old 06-26-2015, 07:47 AM
  #109
Alex Voicu
Before starting on the film covering, i made a few changes to the paintscheme:
ID:	2105838   Click image for larger version
ID:	2105839   Click image for larger version
Old 06-26-2015, 07:50 AM
  #110
Alex Voicu
Stab film covering:
ID:	2105842   Click image for larger version
ID:	2105843   Click image for larger version
ID:	2105844   Click image for larger version
ID:	2105845   Click image for larger version
ID:	2105846   Click image for larger version
ID:	2105847   Click image for larger version
ID:	2105848   Click image for larger version
ID:	2105850   Click image for larger version
ID:	2105851   Click image for larger version
ID:	2105852   Click image for larger version
ID:	2105853   Click image for larger version
ID:	2105854   Click image for larger version
ID:	2105855   Click image for larger version
ID:	2105856   Click image for larger version
ID:	2105858   Click image for larger version
ID:	2105859   Click image for larger version
ID:	2105860   Click image for larger version
ID:	2105861   Click image for larger version
ID:	2105862   Click image for larger version
ID:	2105863   Click image for larger version
Old 06-29-2015, 03:24 AM
  #111
wildwillie3
An Artist at work! Very nice!
Bill
Old 06-29-2015, 10:14 AM
  #112
Alex Voicu
Thank you Bill, you are too kind
A few more images of the finished stabs:
ID:	2106355   Click image for larger version
ID:	2106356   Click image for larger version
ID:	2106357   Click image for larger version
ID:	2106358   Click image for larger version
ID:	2106359   Click image for larger version
ID:	2106360   Click image for larger version
ID:	2106361   Click image for larger version
Old 06-29-2015, 12:42 PM
  #113
serious power
Alex,
Do you have a covered weight please ?
Brian
Old 06-29-2015, 10:32 PM
  #114
Alex Voicu
Originally Posted by serious power
Alex,
Brian
Hi Brian, both stabs are at 101g after film covering.
Old 06-30-2015, 01:21 AM
  #115
serious power
Alex,
Thanks - 15g each for covering so.
I like the blue and gold bottom scheme.
Brian
Old 07-18-2015, 01:44 AM
  #116
Alex Voicu
Thanks Brian. The bottom color scheme was quickly improvised taking inspiration from other models and using 2 high contrast colors from the top side.
I attached a few images of the wing film covering process. Weight after film covering is 370g for the left wing and 372g for the right wing.
ID:	2109775   Click image for larger version
ID:	2109776   Click image for larger version
ID:	2109777   Click image for larger version
ID:	2109778   Click image for larger version
ID:	2109779   Click image for larger version
ID:	2109780   Click image for larger version
ID:	2109781   Click image for larger version
ID:	2109783   Click image for larger version
ID:	2109784   Click image for larger version
ID:	2109785   Click image for larger version
ID:	2109786   Click image for larger version
ID:	2109787   Click image for larger version
ID:	2109788   Click image for larger version
ID:	2109789   Click image for larger version
ID:	2109791   Click image for larger version
ID:	2109792   Click image for larger version
ID:	2109793   Click image for larger version
ID:	2109794   Click image for larger version
ID:	2109795   Click image for larger version
ID:	2109796   Click image for larger version
ID:	2109797   Click image for larger version
Old 07-24-2015, 07:42 AM
  #117
Alex Voicu
A few more images of the film covered wings:
ID:	2110978   Click image for larger version
ID:	2110979   Click image for larger version
ID:	2110980   Click image for larger version
ID:	2110981   Click image for larger version
ID:	2110982   Click image for larger version
ID:	2110983   Click image for larger version
ID:	2110984   Click image for larger version
ID:	2110986   Click image for larger version
Old 08-17-2015, 11:28 PM
  #118
Alex Voicu
The fin post was traced and cut from 10mm balsa, with additional doublers to support the pin hinges:
Fortunately i lasercut 2 rudder spars, so i used the spare one as a guide for drilling the hinge holes. The hinges were attached using high strength epoxy and microballoons, making sure they are 90 degrees to the fin post centerline:
The rudder will be detachable, so i used a carbon rod going through all hinges to save weight. This was joined with a steel rod bent at 90 degrees at the base of the rudder:
The fin post was finally glued inside the fuselage.The slow curing epoxy gave me enough time to check the proper alignment and free movement of the rudder:
The fin post hinges were reinforced with small plywood triangles:
ID:	2115107   Click image for larger version
ID:	2115108   Click image for larger version
ID:	2115118   Click image for larger version
ID:	2115119   Click image for larger version
ID:	2115120   Click image for larger version
ID:	2115121   Click image for larger version
ID:	2115122   Click image for larger version
ID:	2115130   Click image for larger version
ID:	2115131   Click image for larger version
ID:	2115132   Click image for larger version
ID:	2115133   Click image for larger version
ID:	2115134   Click image for larger version
Old 08-26-2015, 11:52 PM
  #119
Alex Voicu
Rudder film covering:
ID:	2116858   Click image for larger version
ID:	2116859   Click image for larger version
ID:	2116860   Click image for larger version
ID:	2116861   Click image for larger version
ID:	2116862   Click image for larger version
ID:	2116863   Click image for larger version
ID:	2116864   Click image for larger version
ID:	2116866   Click image for larger version
Old 08-28-2015, 05:46 AM
  #120
flywilly
My Feedback: (121)
Great looking airplane, Alex! What is the total wing area? The tip chord is pretty narrow. Thanks for sharing!
Old 08-28-2015, 07:41 AM
  #121
Alex Voicu
Thanks Will. The wing area is usually measured by extending the leading and trailing edges up to the fuselage center line. The Audax has a large sweep angle at the leading edge and a fillet at the trailing edge so if i follow the same principle the results may be misleading. That's why i chose to measure the wing area by connecting the left/ right leading and trailing edges with a straight line. In this case the wing area is 67 dm2 or 1039 sq in.
Yes, the tips are narrow, but after looking at the CPLR's model from the 2015 World Championships, i think it's going to be fine
Old 09-04-2015, 11:01 AM
  #122
Alex Voicu
Today's update shows the electric motor installation. The motor is a Himax 6330 Pro, using the front mounting conversion kit from F3A Unlimited:
I plan to test the 0 degrees right thrust setup (as used on the Allure), but it will be possible to adjust the thrust line by shimming the motor mount.
I used a glassfiber plate to trace the 82mm spinner diameter on the fuselage. The position of the plate was carefully adjusted until it was perpendicular on the fuselage center line. For now, the nose was actually cut 4mm longer to compensate for any thrust line adjustments.
Cutting the X mount from 2.5mm carbon plate and the nose ring template from 2.5mm plywood:
Cutting the final nose ring from 2.5mm carbon and preparing the surface for bonding:
Assembling the motor mount:
1mm spacer ring taped to the spinner backplate:
Tacking the nose ring in place with CA:
Nose ring final bonding, using high strength epoxy and carbon rovings:
Rear support structure (2mm glass fiber):
ID:	2118074   Click image for larger version
ID:	2118075   Click image for larger version
ID:	2118076   Click image for larger version
ID:	2118077   Click image for larger version
ID:	2118078   Click image for larger version
ID:	2118082   Click image for larger version
ID:	2118083   Click image for larger version
ID:	2118085   Click image for larger version
ID:	2118086   Click image for larger version
ID:	2118087   Click image for larger version
ID:	2118088   Click image for larger version
ID:	2118094   Click image for larger version
ID:	2118103   Click image for larger version
ID:	2118104   Click image for larger version
ID:	2118106   Click image for larger version
ID:	2118107   Click image for larger version
ID:	2118108   Click image for larger version
ID:	2118109   Click image for larger version
ID:	2118128   Click image for larger version
Old 09-13-2015, 11:15 PM
  #123
Alex Voicu
Installing the hinges and sealing the aileron / elevator hinge lines with transparent oracover film:
Cutting and installing the control horns:
Control linkage:
Pull-pull cable exit holes were drilled, a small segment of bowden tube was attached with epoxy and sanded flush with the fuselage:
Cooling intake holes were cut under the nose. The side intakes were left for later because their position depends on the motor right thrust angle.
Adding the air deflector for motor cooling and the ESC support:
Cutting the vent hole on the bottom of the fuselage and holes for the aileron/ elevator servo leads:
ID:	2119677   Click image for larger version
ID:	2119678   Click image for larger version
ID:	2119679   Click image for larger version
ID:	2119680   Click image for larger version
ID:	2119681   Click image for larger version
ID:	2119682   Click image for larger version
ID:	2119683   Click image for larger version
ID:	2119685   Click image for larger version
ID:	2119686   Click image for larger version
ID:	2119687   Click image for larger version
ID:	2119688   Click image for larger version
ID:	2119689   Click image for larger version
ID:	2119690   Click image for larger version
ID:	2119691   Click image for larger version
ID:	2119693   Click image for larger version
ID:	2119694   Click image for larger version
ID:	2119695   Click image for larger version
ID:	2119696   Click image for larger version
ID:	2119697   Click image for larger version
ID:	2119698   Click image for larger version
ID:	2119699   Click image for larger version
ID:	2119701   Click image for larger version
ID:	2119702   Click image for larger version
ID:	2119703   Click image for larger version
ID:	2119704   Click image for larger version
ID:	2119705   Click image for larger version
ID:	2119706   Click image for larger version
ID:	2119707   Click image for larger version
ID:	2119709   Click image for larger version
ID:	2119710   Click image for larger version
ID:	2119711   Click image for larger version
ID:	2119712   Click image for larger version
Old 09-14-2015, 03:27 AM
  #124
wildwillie3
Awesome Alex! Keep up the great work!
Old 09-27-2015, 11:46 PM
  #125
Alex Voicu
Thanks Bill
I've been working on the rudder pull-pull system. The wires are crossed inside the fuselage so i had to study the geometry of the pull-pull system to make sure there's equal tension in the wires at all rudder deflections. I also had to consider that the wires exit the fuselage through the small bowden tubes (representing 2 fixed points). I determined that a 3mm offset was needed on the servo arm (distance between servo wheel center and wires attaching points). I used 2.5mm carbon plate for the servo arm.
ID:	2122650   Click image for larger version
ID:	2122651   Click image for larger version
ID:	2122652   Click image for larger version
ID:	2122653   Click image for larger version
ID:	2122654   Click image for larger version
ID:	2122655   Click image for larger version
