zen 50 questions
FL
zen 50 questions
Could someone give me info about the weight of the zen 50 with ys 63, how well does it balance, performance, and what pipe set up to use? Info will be very helpful.
thanks
thanks
My Feedback: (38)
RE: zen 50 questions
Dry weight: 6lbs
Balance: 2oz on trailing lower edge of fuselage
Performance: Ballistic
Pipe: None Use standard muffler
Prop: 12x7 apc
Spinner: Truturn (discard original)
Fuel: CoolPower 10% or YS 20/20 for performance
1/8" shims on leading edge of retracts(helps stop nosing over, I fly off grass)
Any other questions: Email me
PineBaron
Prop: 12x7 apc
PineBaron
RE: <span class=
What do you want to do?
The four stroke will need 20% or 30% nitro to match the power of the Irvine on low nitro fuel.
It's much more pleasant to fly a four stroke unless you but a big pipe on the two stroke, tuned to a nice, low 10,000 RPM.
The four stroke will maintain a more constant airspeed since you use a larger prop which will have more down-line braking.
The two stoke will be better for straight line speed if you put a racing prop and pipe on it, but this not really what the Zen is about, though it can move along if you want. The four stroke will have better throttle response for 3-D flip-flopping, and will climb better in vertical uplines once you run out of momentum.
RE: <span class=
IMHO you'll be better off with the IRvine .52 it pulls as big a prop a s a 4c (Irvine's like webra's) are long stroke engines a 12 x 6 is standard for many planes.
You wouldn't have any problems with the Rivine the perry carb is very good at keeping low idling and the engine si VERY reliable
RE: <span class=
I'm building one now & have a Jett Fire .50 on the way. I wanted to use the covered center line pipe design of the Zen 50. Didn't find any other rear exhaust .50 size motor. Any thoughts on this combo? Thanks for the info on the retracts shim.
