FOCUS II ARF construction by-the-numbers
Reply
Old 02-14-2008, 09:32 PM
  #226
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FOCUS II ARF construction by-the-numbers
Focus with webra 160 & MC carb
ID:	878849   Click image for larger version
ID:	878850   Click image for larger version
mtcarey is offline
Old 03-17-2008, 08:31 PM
  #227
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Header broke after eleven flights. Any ideas why?
ID:	906232   Click image for larger version
mtcarey is offline
Old 03-17-2008, 09:18 PM
  #228
lodomjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mtcarey,
Was the pipe supported just behind the header and the end of the pipe too. Or was it supported only at the end and the header supported the front of the pipe?
Larry
lodomjr is offline
Old 03-17-2008, 09:21 PM
  #229
MarkGrabowski
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is your pipe mounted in one place or two? I suspect that if it's mounted in two spots, there isn't enough flex in the system (as your engine moves around on the Hyde mount). There's a lot of leverage on that header when you consider low long the whole setup really is...
Just my two cents....
MarkGrabowski is offline
Old 03-17-2008, 09:28 PM
  #230
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Their are 2 mounts. The front one consists of "o" rings held in place in a way which offers almost no resistance to the header movement
The rear one is a 1/2" silicone tube.
ID:	906311   Click image for larger version
mtcarey is offline
Old 03-17-2008, 09:44 PM
  #231
lodomjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mtcarey,
I ran the Webra 1.45 with the Greves pipe system. I got the plane, engine and all already together and I noticed that the header was made of steel. Your header to me looks like a Mueller header from the photos. I ran the OS 160 with the Mueller header and what we did to keep them from cracking is to cut the header in half or a portion of it to make two parts. Then hold everything together with two couplers. From the looks of the coupler you are using, you will not have any blowouts. Try cutting the next header in two parts and use two couplers and let the header support the front of the pipe. The header will hold it just fine and the extra coupler will give it more flexability so the header will not crack.
Good luck
Larry
lodomjr is offline
Old 03-17-2008, 09:48 PM
  #232
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great! That confirms what I've been thinking. Im going to go this way as a solution...
mtcarey is offline
Old 03-17-2008, 10:00 PM
  #233
lodomjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mtcarey,
I'm not sure where you got your header. The Mueller headers are really nice and I know Horizon imports or carriers the Webra engines and parts including the pipes, headers and so forth. Where the steel header came from that I had, I don't know but it worked great. My engine had the regular two needle carb. and when I first got the thing it almost whipped me. I take pride in my abillities in tuning engines and this was tough. When I finally understood how she worked I actually got to run very well. Shoot, I had someone give me an almost new 1.45 cause they could not make it run. I could get to back flip it the first time every time after the first start of the day, and it ran very economical too. But that's the past and we've moved on to YS.
Larry
lodomjr is offline
Old 03-19-2008, 07:44 AM
  #234
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did this! Far out man! Can you dig it!!!
ID:	907565   Click image for larger version
ID:	907566   Click image for larger version
mtcarey is offline
Old 03-19-2008, 01:52 PM
  #235
MarkGrabowski
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where did you get those nice steel hose clamps?
Old 03-19-2008, 02:40 PM
  #236
lodomjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mark,
Most real good hardware stores will have those clamps. They are not expensive either. I purchased some at an Ace Hardware Store for about .50 each and they work great.
Larry
lodomjr is offline
Old 03-19-2008, 08:15 PM
  #237
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wide-Band Self-Tightening Spring Hose and Tube Clamps
http://www.mcmaster.com/
Hose OD Width Thick. Qty. Per Pkg.
5/8" 37/64" 0.039" 10 7329K11 $3.93
21/32" 37/64" 0.033" 10 7329K12 3.37
3/4" 37/64" 0.051" 10 7329K13 5.59
25/32" 37/64" 0.051" 10 7329K14 5.64
15/16" 37/64" 0.051" 10 7329K15 6.15
1 1/16" 37/64" 0.063" 10 7329K16 7.56
1 21/32" 37/64" 0.075" 10 7329K17 11.32
1 31/32" 37/64" 0.079" 10 7329K18 13.74
mtcarey is offline
Old 05-14-2008, 11:32 AM
  #238
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carbon Fiber landing gears!!!
Where can I get some light weight gears for the Focus II?
mtcarey is offline
Old 05-14-2008, 04:17 PM
  #239
Ryan Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mark,
Look into Bolly gear. ES made some superb gear legs, however the last I heard, they were retooling and are out of stock.
Ryan Smith is offline
Old 05-15-2008, 12:42 PM
  #240
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Ryan!
Im looking at this gear. OK ?
http://www.bolly.com.au/models/undercarts.html
F3A-Wide 110 440 180 42 22 60 back straight
Anyone. Any suggestions on making the focus lighter?
mtcarey is offline
Old 05-15-2008, 01:09 PM
  #241
jlkonn
jlkonn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Call here:
http://pac-rc.com/
Ask for Maureen.
I got Bolly F3A Large gear for my Focus as well as a carbon wing tube from her.
Saved a LOT of weight. I also changed wheel pants and did this for the tank:
http://www.rcuniverse.com/forum/m_31...tm.htm#3134146
Got rid of the 5 cell NiMh and now run a 2s LiPo.
You may also want to consider removing all that from the front of your plane and get a Hyde mount with integrated nose ring.
Good luck!
JLK
jlkonn is offline
Old 05-15-2008, 01:55 PM
  #242
mtcarey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Coke fuel tank! I like that.
Is it holding up for you?
I guess water bottles would work also??
mtcarey is offline
Old 05-15-2008, 02:11 PM
  #243
jlkonn
jlkonn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I went back to a 24 oz Dubro for now but will run the pop bottle again.
It holds up fine but will actually shrink a little bit from the CoolPower 30%. Easy to just screw another one on.
And like the thread says, the round bottle feeds extremely well.
My pix...
That's not a stainless steel bar for wing tube...[X(]
It's just how the light reflected off the carbon fiber.
And yes, my cowl did yellow but Piedmont sent me a new one no charge.
I REALLY like the Bolly gear. The gear and the wheel pants saved me over 6oz from stock.
JLK
jlkonn is offline
Old 09-19-2008, 09:45 PM
  #244
lodomjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lodomjr is offline
Old 09-27-2008, 08:33 PM
  #245
lodomjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lodomjr is offline
Old 09-27-2008, 11:04 PM
  #246
Ryan Smith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
John,
What wheelpants are those?
Old 10-01-2008, 07:26 PM
  #247
jlkonn
jlkonn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ryan,
Ooops!
I just saw your post tonight.
The pants are from Todd Schmidt, D5 Masters pilot and winner of this year's Concourse D'Elegance National Championship at the Nats.
They are holding up great!
JLK
jlkonn is offline
Old 10-05-2008, 08:18 PM
  #248
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At our recent contest, Joseph bought a FOCUS II from Dr. Frank. A great setup and it flies great. Guerin built plane. However it had an instance of the wing tube just a little loose in the sockets was caused by the phenolic developing a bit of slop around the ply end piece. A few cuts, dab of epoxy and micro balloons, balsa pieces to re-cover and some filler to get it all back to new. Joseph wanted a custom color scheme, as usual. He is demonstrating the proper use of razor to lift the old covering off.
ID:	1046658   Click image for larger version
ID:	1046659   Click image for larger version
ID:	1046660   Click image for larger version
Don Szczur is offline
Old 10-05-2008, 08:23 PM
  #249
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And he also has developed a "bat" idea to fly around and scare the teenagers as they come up to the door on Halloween night. E-powered, eyes, nose and mouth, and the motor must be on the front. Its his initial design.
ID:	1046663   Click image for larger version
ID:	1046664   Click image for larger version
ID:	1046665   Click image for larger version
ID:	1046666   Click image for larger version
Old 05-28-2009, 09:27 PM
  #250
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Airplane Focus is back in the air.  The repaired wing and new color scheme per Joseph looks great.  He comments its very visible.  The Webra 1.45 is exchanged for a YS 160 DZ which still runs on the 3 blade with good results.   I got a couple questions on the wing setup also on the Black Magic and its actually a FOCUS I wing not a FOCUS II wing.  A great airfoil.
The only modification I made was to dremel out the first 2 inches of the belly pan, expand the front bulkhead by about a half inch all around, and then glass over the open bay, then touch up paint to seal it up. This provides some additional left-right movement for the header pipe and prevents header from loosening or breaking.
Regards,
Don
Reply
Display Modes
