If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 126 to 150 of 257
  1. #126
    Eric.Henderson's Avatar
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: FOCUS II ARF construction by-the-numbers
    Here are some pictures of finished Focus-2. We flew today - AMEN - So far no mixes :-)
    Four screws on canopy
    side view
    Os 1.60 in cowl
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	115792   Click image for larger version.
ID:	115793   Click image for larger version.
ID:	115794   Click image for larger version.
    If it has wings I\'\'ll fly it....
  2. #127
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry I got a bit crossed over on the picture uploads
  3. #128
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finished plane after test flights...
  4. #129
    Join Date
    Nov 2002
    St. Peters, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm getting ready to mount my engine. Took some measurements on the engine mounting box as it came with the ARF versions of the Focus 2, and I'm coming up with over 4 degrees of thrust offset. Is that right?
    Phil
  5. #130
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got this note in my e-mail, but "reply" do not work??
    "Eric, I noticed that you put Temptation wings on your Focus II's, could you tell me the difference? "
    Here is my reply:-
    I did not put Temptation wings on my Focus-2, although I did change the covering a little.
    My Focus-1 had Temptation wings and stabs. This was for two reasons. I already had a Temptation and liked the way the wing worked. My Hydeaway used Temptation wings and gave same results.
    I also fitted two different wings to my Focus-1. The second wing was a 3-D wing with 5" wide full span ailerons. It also had a Temptation stab with counter balanced elevators. I had the wings and stab made by Dave Guerin.
    The normal Temptation wing has the ailerons out to the tips and this seems to stop the snap rotation more predictably. Also the Focus-1's had heavy wings so having lighter ones made for me made sense. Got my Focus-1 down to 10 lb 1 oz.
    My latest plane is a Focus-2 and has the ARF supplied Focus-2 wings. They are just about the same as Temptation wings. They are nice and light. My Focus-2 pair weigh a combined total of just under 2 lb, including the CF wing tube.
    I also converted this stab to have counter-balanced elevators.
    If you look real close you can also see that my Focus-2 wing adjusters are in the wing panels. This allows me to swap in the 3-D wing without resetting the wing incidences. It also made field tuning a doddle...
    Regards,
    Eric.
  6. #131
    fishgod's Avatar
    Join Date
    Dec 2001
    Wasilla, AK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My throws may also have a bit more down than up when flying the Masters routine, for the spin. I do not use ailerons to get a spin.
    ELevator is 15 degrees up anmd down with about 40% expo.
    Ailerons ar 12 degrees up and down with about 15% expo.
    Rudder is about 2" each way.
    Eric,
    Were these your high rates?
    Regards
    Michael
    www.alaskarc.org
  7. #132
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Michael,
    I don't use rates. I do use 40% expo to soften the elevator and rudder for normal maneuvers.
    For extreme throw maneuvers, like spins and snaps, you go full deflection and go right through the expo curve to the stops.
    Regards,
    Eric.
  8. #133
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My latest info is that it is Ultracote Deep blue.
  9. #134
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Eric I have a theory about too much expo. I think the way you setup the expo leaves the plane too sensitive in the middle of the stick on the pitch. I leave the expo at 20% up and 15% down. The plane is more sensitive at center but less prone to jumping if I'm a little off. I like the feel of the plane as it is. If extreme is needed I assign all 3 controls on 1 switch for dual rate. I use the dual rate on the spins and snaps. But hey that's what I think works. Mike
    Mike Mueller
    Gator-RC.Com F3aUnlimited.com
    1800 380 9373
    mike@F3AUnlimited.com
    mike@gator-RC.com
    Distributor and Retailer of TopRCModel Airplanes
  10. #135
    Join Date
    Mar 2002
    columbus, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I still like my Focus II after four more flights yesterday, did my first rolling circle ever (Real high, but still a rolling circle!). BUT!!!, I had both wing adjusters come off on one side in flight. I noticed that once in a while the plane would respond funny, brought it in and found them popped off and the wing could be moved about 1/2" up or down. I had CA'd them to the plywood plate per theinstructions, but they just popped off. Coulda a been a disaster. Probably epoxy and a screw this time.
    Jeff
    Jeff
  11. #136
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Man Jeff your lucky you still have a plane. Mike
    Mike Mueller
    1800 380 9373
    mike@gator-RC.com
  12. #137
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have been e-mailed that some guys are putting counter-sunk screws, through the fuselage sides, from the outside into blind nuts.
    Glad you saved it.
  13. #138
    Join Date
    Mar 2002
    columbus, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    At Toledo, I found some Nylon, 6-32, socket head capscrews for the canopy. Save some serious weight (relatively speaking) over the steel ones I was using.
    Jeff
  14. #139
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nylon will work, Be careful to not strip out the hex heads. (been there!)
    The FOCUS-2's were given a good outing this weekend at the Green Sea pattern contest. Myrtle Beach SC). It was a bit windy and 45 to pure cross both days. The Focus-2's took 1st and 2nd in Masters at the hands of Mike Hill and Dave Guerin who beat out Gary Harris into third place, (with his new Temptation). Engines used were YS 1.40L, Webra 1.45 and YS DZ respectively.
    Lee won FAI with his new Focus-2 and mine was third after it logged its 14th flight. My position was really only a 3rd out of 3, but I mention it because the plane allowed me to compete in FAI with no practice. I had actually practiced Masters on Friday as I dialed in the plane. It let me fly an unfamiliar routine in hostile wind conditions and not be last in three of the rounds.
    As I posted earlier, I think that a lot of people will do well with this plane and will enjoy the way it helps them fly. If you have an old Focus-1 you will see a positive difference. If you have a Focus-2 for the first time you might just simply like the way it flies.
    Sorry if this sounds too much like a commercial, but I really do like the performance for the price that it offers to all pattern pilots. New and existing can't help but benefit when a plane encourager's more pilots to become contestants.
    The only problem I have now is persuading my body to go back to NJ ;-)
  15. #140
    Join Date
    Mar 2002
    columbus, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK, last night I put some tapered head screws through from the outside with bolts to hold the wing adjusters in place. One more popped off when I was drilling the holes, so I epoxied all of them at the same time. I also put a bigger control arm on the rudder servo and now I have full throw (about 1/4 from touching the elevator halves). I have to thank Steve Maxwell for supplying the extra hardware. Now it's ready for competition!
    Jeff
  16. #141
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ref. "Eric I have a theory about too much expo. I think the way you set up the expo leaves the plane too sensitive in the middle of the stick on the pitch. I leave the expo at 20% up and 15% down. The plane is more sensitive at center but less prone to jumping if I'm a little off. I like the feel of the plane as it is. If extreme is needed I assign all 3 controls on 1 switch for dual rate. I use the dual rate on the spins and snaps. But hey that's what I think works. Mike"
    Mike,
    I have read this several times and I don't understand the note. I would like to. I am gessing that you might be talking about what happens somewhere between neutral and the extreme end of the stick travel?
    With my 10X I use the "curve" option and there is no "jump". Even at 40% or 60% expo the transition on the graph and the control surface is not violent. Also, the throws within the soft part of the higher expo rates perform all of the maneuvers except the snaps and spins.
    Did I guess right?
    Regards,
    Eric.
  17. #142
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Eric again I'm sure you have it right. I'm going to do the same thing with the curves on my 10X. Thanks for the heads up. Also many people don't realize that when you use a control arm off of a servo that it has built in reverse expo. Have you ever explained this in your MA articles? Us mode 1 guys have to stick together you know. We're a dying breed. Happy Easter to all, Later, Mike
    Mike Mueller
    1800 380 9373
    mike@gator-RC.com
  18. #143
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mode-1 has advantages that we will keep to ouselves (VBG).
    A trick that I will share is that you can use expo to make the rates all appear to be the same in normal stick usage, For example, around the first 1/4 of stick movement. What this means is that you can have more throw selected but still have the same smooth behavior around the positions where your sticks are used the most.
    Take the case of the elevator. First of all set your three rate throws, e.g. Low, medium and high.
    Then with the expo option do the following:
    - Move the stick to 1/4 defection (It can be more or less according to taste, this being just an example)[There are graduations on most stick gimbals to show you how much the stick is deflected]
    - Set your expo for the low rate, say 25%
    - Switch to next rate and add expo until the elevator throw is the same at 1/4 stick deflection
    - Switch to next rate and again add expo until the elevator throw is the same at same stick
    deflection.
    You will get numbers Like 25%, 38% 56% or whatever.
    Now you have a plane that will fly the same at any rate you select. Usefull for such things as landings and take-offs etc. It will have different and desired behavior at greater stick deflections.
    Another way of saying this is that high rates do not have to mean a more twitchy plane to fly.
  19. #144
    Join Date
    Dec 2001
    Kennesaw, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Jeff....
    Glad to hear you are liking the Focus. I miss mine. Hopefully you and Steve will do well this year!
    Later,
    Pugs
    Jon Uhler
    aka. Pugsley - Battlefloydflyer
    http://www.extremeflightrc.com
    founding member http://www.torkitordorkit.net
    moderator of gsael
    gsael-subscribe@yahoogroups.com
  20. #145
    Pro pattern's Avatar
    Join Date
    Apr 2003
    Savaneta, ARUBA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That is a very good tip, Eric.
    Thanks for sharing it with us.
    Danny
    Nobody is perfect, I am nobody .............. 3rd place, is just 2nd best loser
  21. #146
    Join Date
    Jan 2002
    Hoffman Estates, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks E. I'll do it just the way you stated. Thanks for your insite. Mike
    Mike Mueller
    1800 380 9373
    mike@gator-RC.com
  22. #147
    Don Szczur's Avatar
    Join Date
    Jan 2002
    Chantilly, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yawn....
    Wheel pants complete. Put a 1/32 piece for larger surface area inside the pants. Next put in a 1/4 inch block for the screw head to fit into. I drilled it 1/8 inch so it snug in there and keeps the wheel pant secure. A drop of CA to strengthen the wood where the screw head recesses and then mounted the wheel pants. The screws (supplied as axles) buldge out the wheel pants a bit to straighten them with respect to (making them more vertical). They look fairly aligned.
    Mounted header and cleared cowl hole for one of the new Central Hobbies headers. Its similar clearance to the old central hobbies wrap-around header, but its more square clearance hole that is about 1/2 inch forward of where the standard cutout is on the old wrap-around style. Not as much cutout needed behind this, because the new header is shaped kind of like a Z and gets out of the way quickly without the need for a long cutout for cowl clearance.
    Night.
    Don
  23. #148
    Join Date
    Feb 2004
    Oakland, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I noticed that there are 2 pieces of plywood with 2 holes drilled in them labeled D27 - what are these for? The pieces are 7/8"x7/8" aprox. in size.
    Also, could someone post some pictures on how they mounted their throttle servo and fuel tank?
    Thanks.
    -Derek
    Team Futaba
  24. #149
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My order for ultracote finally came into my local hobby store. I can now confirm that the ARF blue is indeed Ultracote DEEP BLUE and not Midnight blue as posted earlier.
    Regards,
    Eric.
  25. #150
    Join Date
    Sep 2003
    HENDERSON, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey Don,
    I flew and dialed the 3-D version this weekend. I still had the FOCUS special wing that Dave Guerin made, I believe that you have one as well. The 5" wide, almost full span ailerons give a fantastic roll rate when going vertical. Too fast to count. At low rates the plane would fly the routine and came out of snaps straighter than the regular wing!!
    It was a blast to fly. Will you configure yours with two types of wings??? I can't wait until you fly "yours", ("yours" being the regular Focus-2), to see if you find the version 2 differences to your liking. It does a great 4 of 8 entry into the 1st P-05 maneuver....
    Regards,
    Eric.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
