New CA models Epsilon build (easy as pie)
RE: New CA models Epsilon build (easy as pie)
Well if a 20 oz tank can fit, then a 8 or 10 oz should not be a problem Thanks for doing the photo.
Simon, let us know if Weston do start to bring CA kits in (and make sure they bring the kits as well as the ARTFs in!)
Tph1 unfortunately not!
I did try to get a pipe in but without modyfying where the undercarrage goes or dropping the manifold right outside the bottom of the plane I could not make the pipe I have fit[:@]
What made the decision for me was the video on CAM website ... it sure performs amazingly well on a 90 with a muffler so I thought I would keep it simple and as the plane and all the hardware has come out at ...... well what do you guys rekon the weight will be uncovered ??
How does 6lb's 8oz sound [sm=sunsmiley.gif]
If it doesn't perform on that I then I do have a 108 looking for a home[X(] but it is somewhat heavier than the 91[:@]
What sort of weight is covering on a plane this size normally??? .... this will easy be under 7.5 lbs full of fuel and flying!!
I have a rebelove that weighs more than that and goes vertical at half throttle so I see no problems there!
No decent vertical with a 61-may pullout from a hover if you stuck a tuned pipe on, but will be at top revs and look like a struggle. 91 is definitely the way to go with this weight.
Let us kno how the ASP goes, thinking of getting one to upgrade my 3D funfly for the show season
#32
I just love the looks of this airplane, and the video of it is impressive, im so tempted.. would the .91FX be good enough? do I need a pipe? what about standard servos, are they enough?
#33
Hello,
as i know Bart-Modellbau in Germany is the distributor for Europe, they have the Epsilon Kit for 'only' 215€.
www.bart-modellbau.de
#34
My Feedback: (16)
TX
I have been drooling over this thing since day one... back in January. After I found out Western Union transfer and shipping cost, and the projected arrival of the regular shipment was only a month away I decided to wait. Sold the Wide Body 60 kit... and now I found out the container should arrive in only two more weeks. I want one.. new 110 and digi's are awaiting a home.
Looks good BTW.. get it covered and tell me how she fly's!!!
#35
hello 3dukidding
just today i buy an Epsilon, do you tell more about the engine and the prop and the type of fly?
I whant put an Super Tigre .75 , what do you think?
thanks
Sergio
thanks
Sergio
#36
I just buy an Epsilon but must wait 1 month to have it. It is possible to have answers to the following questions ?
What about the CG with the OS91Fx ?
It is possible to place the servos (stab) at the rear ?
What about the weight ?
Thanks for the answers.
Dominique
Dominique
#37
Was tested with OS91FX...CG is no problem.
Will be tail heavy with servos in rear. Also..its bad to move mass away from the center of a plane. This makes tumbling maneuvers and snaps harder to stop precisely. Use stock servo locations with pull-pull linkages on the rudder and elevators.
The prototype was 7.5lbs.
ORIGINAL: Dominique ACM
Dominique
Dominique
#38
Thanks a lot,
7.5 lbs: i've got the same weight with my SYNERGY 90 3D.
I will use a kato system for the elevators servo.
We will see this problem when my kit will arrive.
DG
DG
#39
My Feedback: (17)
QC, CANADA
It seems that Marcelo Colombo like the tail heavy planes...
My 24%CA Extra300 had the same CG issue. I solved it by installing a MK bellcrank on the elevator.
Dominique
Which muffler are going to put on your 91FX? Or better, Quel muffler vas-tu installer sur ton moteur
Dominique
#40
Hello,
On my Synergy 90 3D I'm using a OS91Fx + Genesis muffler (Braeckmann Modellbau) + 0% Nitro + APC 14x8 (9900 RPM)
On the Epsilon I will use the standard muffler with another 91Fx, the APC 14x8 and 0% Nitro (9000 RPM) or 10% Nitro (10 000 RPM).
I don't think that we will have enough place to install a muffler. Can somebody tell us if it's possible ?
DG from France
DG from France
#41
My Feedback: (17)
QC, CANADA
I have heard good comments on that 'strange' muffler from turbo jett incowl muffler
1) http://www.jettengineering.com/
Specially for The Epsilon, there is not room to fit a big muffler[]
APC14x6, 11500RPM, 15%Nitro
Ultrathrust is a good one too!
2) http://www.pspec.com/html/muffler.html
Daniel
Daniel
#42
Adrian, sis you set up a plane with pull pull on elevators? If so how did you do it becauase I have to take the choice now as to use pull pull or two servos at the back. I am probably going to go pull pull, but will leave holes in the back just in case.
#43
Just maidened mine last weekend. It only needed a little up trim which wen away when I put the cowl back in (first flight was with no cowling). There is a very clear flight speed difference between the uncowled plane and the cowled one. I tracks very nicely except for the slight pull to the canopy in downlines. It weighs 7.8lbs with the OS 91 FX, Hitec Digitals, and a 4 cell 2000mah NiMh pack (my ony available).
The plane builds fast and is very accurate. The only dark points are the instructions (worthless), the diedral brace fitting (much more than the 4mm diedral recommended in the same manual), and the cockpit balsa (so hard it wouldn´t bend to conform to the turtledeck). There were no accesories whatsoever in my kit (not a single screw, horn, clevis, etc.) but I would have substituted them anyway.
The elevator pull-pull setup is a slight pain in the neck. I guess the next time I would go with the MK system. I alse needed to add a couple of 1/8 shims under the elevator servo to clear the lines with the rudder servo located to the back.
Other than that, it is the best 60-90 size flyer period. I gave my Swallow 90 away after flying this baby. The Epsilon is much more agile and nimble than my friend´s Widebody 60. The Epsilon will go from pure F3A style flight to 3D with no sweat. I will take some pictures next weekend weather permitting.
#44
My Feedback: (17)
QC, CANADA
Hello Aresti
I agree with you, a MK bellcrank would be easier to install. What muffler are you using on the OS91FX? The cowl seems very small on that plane?
#45
I´m using the standard muffler. I cut the cowl almost from end to end (lenght-wise) to clear the muffler in the bottom side. The problem is not the muffler, but the fuselage. The muffler extends almost to the landing gear block.
#46
http://www.rcaerosport.com/articles/...trol/intro.htm
LOOK THIS ALTERNATIVE FOR ELEVATOR V/S PULL PULL
SERGIO
SERGIO
#47
OR
I'm interested in getting either the WB60 or the Epsilon to begin competing in sportsman class this year. Which one would you say flies pattern maneuvers better, opposed to 3D which the Epsilon seems to be leaning towards.
#49
Just thought I would explain why I have not had a chance to update []and I appologise to all who have asked me questions that I have not replyed too ..... you will see below My beautiful daughter which has somewhat distracted me from this project but further down you will also see a coverd epsilon!! dammit that took a while
