If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 18 of 60 FirstFirst ... 8161718192028 ... LastLast
Results 426 to 450 of 1497
  1. #426
    handglider's Avatar
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Black Magic v2 builder's thread! *Updated*
    HI Ian,
    I've only installed the rear wing adjuster as I am also thinking about just using a nylon bolt thru the forward position. since this is an after thought I am going to have to epoxy in a nylon threaded insert at the root. It would be easier than having to add that little ply plate and drilling/tapping etc...
    I haven't discussed the pros and cons with Mike yet about this, I am sure he will give his opinion.... Mike?
    I've got a buys 3 days at my "real" job coming up - so she will be sitting pretty on much bench - I like to let the dust settle a bit anyhow.
    I've weighed everything going into the airframe and I should be right under 9 lbs going into finish..... So I am hoping that I will finish out at under 10 lbs...
  2. #427
    PatternPilot's Avatar
    Join Date
    Nov 2002
    Knoxville, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mike,
    Looks real good, I was wondering how you did the mount for the electric... It just sparked some idea's... Oh no
    see you in a few weeks at the NATS.. going to Lamar's to get some time in on the Aggressor and practice..
    scott
    Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com
  3. #428
    Join Date
    Apr 2006
    London, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Carbon formers
    Arrived this morning, I have also managed to get 2 full sets made from balsa and ply. The carbon ones are very very nice something that supprised me that in there 1.5mm thinckness was the stiffness, there is extremely little flex which can only be a good ting. The weight of them total is 170g. Where they expensive YES, ideally they would of been 2mm but this would of pushed £90 ($170) but in 1.5mm they are were £55 including shipping & vat ($100).
    Initially F1 looks welll out of scale but the others look ok, these were taken from Hangliders drawings and i'm supprised there was an issue but i'll get it re-made.
    Here's some piccies :-
    [img][/img]
    90% of the problems a pilot encounters in the air, he chose to take into the air with him !!!
  4. #429
    Join Date
    Apr 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have 3 sets of formers now and only 2 sets of wings . . . ummmm . . .. . . . doh !
    These things are perfect, i've measured them and matched them up with the balsa/ply versions and they are exact .. i'm so happy.
    Firewall - probably the biggest plus, with the 2mm ply F1 bonded to the back of the carbon F1 it is only 3.5mm in thickness and is easily strong enough to mount the engine to, god knows how light it is but as i said the total was only 170gm.
    I am taking orders if anybody wants some
  5. #430
    MHester's Avatar
    Join Date
    Oct 2002
    Woodstock, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: UK_Flyer
    Hmmm.....I'm not really sure how I feel about that yet.......I better sleep on it. My first reaction is "cool", but my second one is begging for radio interferance. My third one.....well it's been a long week. I need rest.
    -M
    Thanks to my sponsors over the years!
  6. #431
    MHester's Avatar
    Join Date
    Oct 2002
    Woodstock, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    BTW they do look really cool [8D]
    -Mike
  7. #432
    Join Date
    Mar 2005
    Saffron Walden, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Incidentally, Mr. Hester, Why are there so many formers between the back of the wing and the tail?
    Just curious, because I've made a few 2M O/Ds with quite similar fus. construction(balsa sides,corner longerons(1/2 triangular),foam top and bottom decks.)
    I do strengthen the inside of the balsa sides with 60 gram kevlar/epoxy, but the only formers are two carbon/blue foam ones at the back of the wing seat and in front of the tail.
  8. #433
    Join Date
    Apr 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MHester
    ORIGINAL: UK_Flyer
    -M
    I'm not in it for the profit, there at cost price, i've just used them before so already have a good relationship. If you dont want me to thats cool
    What might also be worth considering is the following. :-
    1. The DEPS system could be drilled straight into the formers and would not require any building, therefore no extra parts or weight,
    2. Same with the aerial tube, A whole could be drilled down through each of the formers and would only need one dab of epoxy to hold in place.
    Interferance, I had actually considered using a whip antenna like the jet boys, but even if i do run inside i've see people use carbon tubes to run the aerial in.
  9. #434
    Join Date
    Oct 2003
    Melbourne, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Uk Flyer
    If its ok to ask, where did you get then produced or did you do them yourself. I have two other projects I am working on in cad format already and would loved some carbon fiber pieces made for them. Do you know if they can do honeycomb sandwhiched between fiberglass as well ? I havent found the best way to cut this stuff yet and its very strong and 1\10 the cost of carbon fiber. I know this is a little off subject
    Troy
  10. #435
    Join Date
    Apr 2005
    huntsville, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    MR. HEASTER!
    gary
  11. #436
    MHester's Avatar
    Join Date
    Oct 2002
    Woodstock, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    After sleeping on it (I can't think clearly when I'm that tired) I'd say have at it, they do look cool. Just understand that that's a lot of carbon in the tail area, and they do weigh a bit more than the wood formers. I do like the F1 and F2 very much, as well as the partial top formers. The rest I think are overkill, and add possibly too much weight and carbon in the tail.
    As for why I use so many....."just because".
    Because personally, I can make a stiffer, lighter rear section using this method than with a laminate, without risking stress failures. It also supports the sides very well all the way down, and it absorbs the resonant vibration of certain engines pretty well. That being said, it could get away with a couple less, but it just works this way.
    Bolts instead of front adjusters: Suit yourself. That's just personal taste really. I like to have adjusters in the front and rear, and pin my tubes at the ends of the tube through a hard point in the wing. There is so little stress on that pin, it's ridiculous. It's just the way I do it and it works for me. It also allows me to just slide the wing panels on, tighten ONE screw and I'm ready to go. Don't even have to remove the canopy.
    -Mike
  12. #437
    MHester's Avatar
    Join Date
    Oct 2002
    Woodstock, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: f3a05
    BTW, great looking plane!
    -Mike
  13. #438
    handglider's Avatar
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mike,
    yea, I think I am going to stay with the front adjusters. I was thinking I could also use one of my laser to align the hole at the end of the tube... was worrying a little about that.
    Ian, please give use some weights for the individual formers, I would like to compare them to the balsa weights.
    Been taking a little break for building today, just purchased a nice used full size van today, also I have been designing a trim scheme for my plane, I'll post some more drawings when I get a chance.
    cheers, dean
  14. #439
    Join Date
    Apr 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Carbon Former Weights,
    This one supprised me a bit but i had always intended on attacking them with a hole drill anyway as there's still more than enough stiffness even so i dont think it will reduce to the same extent.
    I am also considering dropping 2 formers probably F8 & F6,
    Part Carbon Balsa
    F1 36g 16g
    F2 41g 17g
    F3 28g 6g
    F4 17g 4g
    F5 16g 4g
    F6 12g 3g
    F7 10g 3g
    F8 8g 0g
    F9 7g 0g
    Total 175g 53g
  15. #440
    handglider's Avatar
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Ian,
    I think those are some of the coolest Black Magic parts I've seen to date. All that carbon would dress up the plane big time. I was also suprised at how much heavier the carbon formers are. I have only built one complete airframe but I have framed up 3 fuselages and I would suggest using all the formers and using contest balsa from f4- f9. The fuse that I just built is very strong, you would knock someone cold if you hit them over the head with it : ) I mean it, there is a lot of wood in this thing and yet it is very light and strong.
    IMHO - Since the balsa formers are so light you should use them all, also if you are running a 4C do the 1/4 stick cross bracing like I did in previous posts... It's still lighter than just running those carbon formers.
    So at this point I am wondering the advantages of the carbon formers. considering the weight of f4- f9 in balsa is only 14 grams.
    The former set that I used in my build was at 112 g total and that is with a 3/16" 5ply F1 - 1/8" 5 ply f2 - I used heavy 1/8 wood for f3-f5 and super light contest wood for f6-f9.....
    man that still floors me that the carbon set is so heavy, what is the make up of the carbon in these formers??
    The other thing about the carbon formers is that you will have to use epoxy to glue these in, that will add a lot more weight too. Compared to just CAing the balsa formers in....
    Plus I think a balsa to balsa CA joint (former to fuse side) might be stonger and less stressfull to the balsa fuse side......
    these are just my thoughts so, chime in ya'll....
    But man, those carbon formers look awesome, I am going to layup some light balsa formers with 2oz carbon cloth and compare weights.
    Balsa - the magicial wood : )
    cheers, dean
  16. #441
    Join Date
    Mar 2002
    Orange Park, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just cover the balsa formers with carbon fiber colored monocoat, just the ones and sides you can see. BTW, looking good dean, I want to see it fly in Jacksonville.
    Brian Billings
  17. #442
    handglider's Avatar
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Brian,
    thanks man !! I've been having a good time building her too.. Just ordered all my painting equipment and I will be starting the sanding and finishing real soon, I am hoping to fly it at the Huntsville, Jacksonville and Districts.... we will see, I've got lots of work still....
    Yea I am looking forward to the Jacksonville meet, have heard great things about it from Jim and Mike, can't wait - I'll be there !!!
    Dean
  18. #443
    handglider's Avatar
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi All,
    A few more detail pics of my build. The fuselage is amazing at 2 lbs 12.5 oz.
    enjoy!
    Dean
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	490277   Click image for larger version.
ID:	490278   Click image for larger version.
ID:	490279   Click image for larger version.
ID:	490280   Click image for larger version.
ID:	490282   Click image for larger version.
ID:	490283   Click image for larger version.
ID:	490284   Click image for larger version.
ID:	490285   Click image for larger version.
  19. #444
    Join Date
    Apr 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, here's where i've got to. One thing i was supprised at is that to get to this point was not hard. I'm not far away from sticking it on the Jig and gluing, jigs not finished yet, probably becuase i've spent to much time on the below. Wing joint holes were the most time consuming but i've measured with a digital vernier back and front and there spot on.
    Still havent skinned my stabs or top and bottom cores, which i think really should be my next step. Jig is nearly finished but i'm waiting on the table now, Unfortunatly i'm not lucky enough to have a massive basement like you US guys, i'll show you pics when i'm its done but i'm in a little 1 car garage with all the spiders
    Question 1. in roughly putting together the below i noticed there could be some room for the stab tube holes to move and then not be straight. What i'm toying with the idea of doing is making 2 ply jigs to hang of the end of the stab tube then i can guarantee the tube is level in the fuselage before gluing, then glue all at the same time.
    Pictures dont do it justice, i've already had this on a laser sight, on beam mode i can spread the beam along the top thats how flat it is. On its cross mode i can see the wing tubes are level and a good sign is there already aligned even.
    Images are linked, for some reason it wont attach - just errors
    http://img.photobucket.com/albums/v4...IMAG0005-1.jpg
    http://img.photobucket.com/albums/v4...IMAG0004-1.jpg
    http://img.photobucket.com/albums/v4...c/IMAG0002.jpg
    http://img.photobucket.com/albums/v4...IMAG0001-1.jpg
  20. #445
    MHester's Avatar
    Join Date
    Oct 2002
    Woodstock, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Those pics show why it's vital to have a jig for that fuse
    Great work, except for the tail block (I'm being picky LOL)
    The wood work looks superb, keep pressing I can't wait to see it framed and finished!
    As for the stab tubes, if you know your stab holes in your halves are perfectly straight, then that's a good method. I like to actually mount the halves and glue the center in with the stabs supported in position.
    You can think yourself to death with this plane, and in the end you'll think "Gee that was easy". There are some steps that are a PITA, but most of it is very easy, fast and straight forward. It's basically a very square box with rounded cores and composites attached.
    Now I have to finish packing for the Nats....
    -Mike
  21. #446
    Join Date
    Apr 2005
    Calgary, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Has anyone built a gas powered version yet? I keep looking at the Brillelli 40 and the Black Magic and thinking, "hmmm". It may not make the 5kg limit, but it would be close and I am not looking for a contest plane, just a great flying sport plane to enjoy and improve my skills with. Combined with a great budget gas engine like the Brillelli, and it would be a super economical way to have a 2m pattern plane that flies for pennies per flight...
    Mark
    Waco Brotherhood #4
  22. #447
    Join Date
    Apr 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MHester
    -Mike
    Do you know what, i knew you'd pull me up on that.
    Trying to recover here that was just a quick block rushed together for alignment, it was'nt even sanded just "carved", i'm working on the other for when the jig work starts. Doing everything in two's at the moment takes its time.
  23. #448
    MHester's Avatar
    Join Date
    Oct 2002
    Woodstock, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm just teasing Ian
    -Mike
  24. #449
    Join Date
    May 2002
    Coarsegold, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mike,
    Instead of a full composite model, have you any plans for a glass/carbon fuse with foam wings?
    BTW - good luck at the Nats, wish I could go
    Tom M.
    Fresno-Madera Jet Rally Sept. 21-24, 2017
    WWW.FRESNOJETS.COM
  25. #450
    Join Date
    Oct 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Handglider
    I have sent you a pm. By the way your planes looks great, can wait see it finished
    Troy
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
