Venus II
#1551
MI
RE: Venus II
Thanks d!
I will probably go with the Hitecs. It looks like the plane is going to be ~8.5# AUW even with the heavier servos in the back.
Regards,
Jerry
Regards,
Jerry
#1552
My Feedback: (90)
RE: Venus II
Sorry to high jack the thread.
I have three futaba 9202 servos for sale (pulled from my Venus II that I am selling). Each weighs 1.8 oz, has dual bearings and a coreless motor. Smooth movement and excellent centering capability. I used them for rudders and elevators.
I used an YS110 for power and did not need any tail/nose weight.
Please check my RCU ad. Ask $105 for three.
#1553
IA
RE: Venus II
I am putting together my 2nd Venus 2 and am ready to put onthe belly pan and line up the bolts for the wing. The last time I did this, the bolts getting lined up was a royal pain.I would have rather had a root canal! Also, I must have been off just a bit as it was a struggle to get the wing on at the flying field.Any ideas on how to accomplish this?
Also, I am putting a 120 AX on it with a 17x6 prop. This propis a bit large for the spinner. Are there any vendors that have spinners that can accomodate an APC prop of this size without having to cut on the spinner?
Steve
Steve
#1554
IA
RE: Venus II
One other thing, I had to add a bit of weight to the tail of my other Venus with an OS 91 FX with the engine sitting at 6 1/4 inches forwardas per the instructions. Is there any problem with moving the 120AX back toward the firewall an inch or so to help with c.g.? I realize that the cowlhas to fit so can't go hog wild.
Steve
Steve
#1555
RE: Venus II
I have an OS120AX in mine, mounted in the normal,(forward), location. I mounted the battery as far back in the radio area as I could. This 6 volt 2500mah battery is just above the wing bolt plate. It balanced pefectly with no lead. I have since moved the tank back to the CG and added a pump that mounts on the engine mount between the engine and the firewall. I guess th weight of the pump exactly countered the weight shift of the tank as this plane still balances at the recommended spot with no lead.
#1556
MN
RE: Venus II
ORIGINAL: medicap
I am putting together my 2nd Venus 2 and am ready to put on the belly pan and line up the bolts for the wing. The last time I did this, the bolts getting lined up was a royal pain. I would have rather had a root canal! Also, I must have been off just a bit as it was a struggle to get the wing on at the flying field. Any ideas on how to accomplish this?
Also, I am putting a 120 AX on it with a 17x6 prop. This prop is a bit large for the spinner. Are there any vendors that have spinners that can accomodate an APC prop of this size without having to cut on the spinner?
Steve
Steve
Or place in 2-tubes so the bolt goes through the tubes and can't fall out of allignment???
Not sure what the wing comes with, but haveing nylon 1/4 bolts have always worked well for me...
#1557
MN
RE: Venus II
I keep wondering about picking up this plane and stick my os 1.20 ax with pipe...
Power was litrally amazing.... the pipe added 900rps to the 17x6 apc prop...
It was unreal on a 69" yak... But the low end was lacking for 3d....
My thoughts..... If you want a great engine for this plane.... OS 1.20 ax will knock you socks off....
If you want more power...add a pipe....and you could do any routine....no problem..
I will wait till summer, as I had some issues with tunning with the pipe...
this may be fuel tank clunk related....
May add a pump and have not issues....at all with a muffled pipe...
Some say that the carb on the os 1.20 ax is too big and can make the settings sensitive...
If you use the stock muffler...it will work perfect....set and forget....
It is pipes that may be more of a issue...
Will report in spring...
#1558
RE: Venus II
ORIGINAL: medicap
One other thing, I had to add a bit of weight to the tail of my other Venus with an OS 91 FX with the engine sitting at 6 1/4 inches forward as per the instructions. Is there any problem with moving the 120AX back toward the firewall an inch or so to help with c.g.? I realize that the cowl has to fit so can't go hog wild.
Steve
Steve
#1562
RE: Venus II
Hi,
I checked www.hobbybarn.com and they seem to have in stock (it is not shown as being out of stock). Giving them a call might be worthwhile.
Good luck,
Teo
Good luck,
Teo
#1565
MN
RE: Venus II
Crap....
So they discontinued it????
Are they going to give a 2m pattern plane ago!!!??????
IF they did, it would be a VERY VERY smart move....
2m Sequence F3A perhaps???
What have you heard??
#1567
OH
RE: Venus II
I called Great Planes after hearing the rumor. I was told that they are not going to replace the Venus. But, I guess that doesn't mean that they are not going to release an entirely different airframe. If it is almost a 2 meters, our 125 set up isn't going to cut it. I believe 3d hobby shop is also coming out with a larger Orisis. I'll learn to fly this one...first. I am still considering recovering mine. I have my trim scheme all ready. Just haven't got the nerve to rip all the covering off yet.
#1568
MN
RE: Venus II
This hobby NEEDS a quality ARF pattern plane.....
Geeze....even the weight limit was increased....
to bad they don't have 2-new sizes...
1.20 and full 2m......
Don't want to spend 400$ plus shipping from Worldmodels, for there spoton...
Good aircraft, but spendy.
#1569
My Feedback: (45)
RE: Venus II
ORIGINAL: kochj
Arch
#1570
OH
RE: Venus II
400 plus another 1500 to get it in the air... I have to consider myself fortunate that I have a Venus...I picked it up for 400 RTF. And it looks like it is going to be a long time before I am able to upgrade into 2m plane. It has been said many times that you have to pay to play with the big dogs in pattern. Arch, what do you think the average cost of a bird that is able to compete in the upper pattern classes? It must be close to 4 grand. 2 just for the airframe. For now I will just have to fly the covering off my Venus.
#1571
OH
RE: Venus II
Go to the Great Planes product suggestion form and request a replacement for the Venus II.
http://www.greatplanes.com/suggestion.html
#1572
My Feedback: (45)
RE: Venus II
ORIGINAL: tele1974
I think the 400.00 competitive 2m ARF is a dream that just wont be realized. The most cost effective ARF of the last 10 years that was truly competitive was the Focus series and they were still 750.00 and that was 10 years ago. Something very similar to produce today would easily be over 1000-1100. Have you seen the cost of balsa recently? Throw in the fact that airplanes are getting larger constantly for the new patterns and the cost goes up. On top of that, many people seem to think getting an ARF going is an easy task. A lot of the major companies have someone in China full time to essentially babysit production and watch for quality control issues. Piedmont models was the last ones to successfully get a good ARF in the country, but even Dave Guerin and others will openly admit, you are looking at a significant investment upfront of 25K or more, and unfortunately with the internet today, it only takes 1 or 2 bad models in a batch in the wrong hands and your sales just go through the floor.
Mike Hester tried to do it with kits. He had great kits, but there were guys who wouldn't follow his suggestions, even though he would go out of his way to help people and tell them how to sheet the plane and what cloth to use. Then the plane would come out heavy and not fly well, and they blamed him for it. Mike literally killed himself for 3 years trying to make everyone happy and is paying the price with major health issues now.
I would say most of the models out there today are very good, but out of 100 customers, Probably 75 to 80 are perfectly happy with what they have or have the resources to fix small issues, another 15-20 will quietly go to the manufacturer for help if they have a problem and the remaining 5-10 will be the ones that go online and publicly bash everything about the plane without every contacting the distributor or manufacturer and unfortunately these are the posts that most read and it can quickly destroy the reputation of a perfectly good product or manufacturer who in most cases will do whatever they can to make things right. Can you imagine being a guy who just dropped 30K into a business and had all these great planes ordered, then you get a few guys who buy the absolute cheapest, heaviest equipment out there, over build in the assembly , then complain what the plane weighs when the designer probably recommends equipment that the person didn't use. Then you have the same guy who if he has a plane that will make weight with his equipment complains that the plane isn't built robust enough when he tears the gear out of the plane. These are the people who are making it very hard for us to get good planes in the country.
I've seen people in some threads, such as the Wind S Pro thread complain about the quality. The planes finish and such isn't perfect, but for the painted ARF version at 1999, it is a great deal, especially when you figure it flies as well as the CA and Oxai planes. Granted, the finish might not be as perfect, but I don't see how you can complain about a plane whose finish is 80-90% as nice as the others, but flies the same and will make weight at 60% the cost or lower. Doesn't make sense to me.
Arch
#1573
MN
RE: Venus II
Good points....
I think that most look at a 50cc plane and think...hmm...600-700$ for best .....okay...
a pattern plane is 30cc plane...It should cost 400$ like the 26-30cc extras and sbachs that are everywhere now...
I don't think a pattern plane has any more balsa than anyother plane in the same size? ???
Are there Lighter balsas?? I had thought that there isn't a measure of good or bad balsa, but placing proper rating material in the
proper area... ( A.B.C ) These are equally good, but have diff. places in a aircraft build..Ex. some bend easier, or are stiff ect...
I have a EF 78 " extra gas version that I have to build, and could use in pattern....But I would like to have a pattern specific tool
rather than dual purpose...
I thought the VenusII was a popular plane....??? Perhaps too exspensive to build, and not enough money charged for the increase in cost to build???
It seems that is the current trend of the big Two... Get rid of the older aircraft...redesign and charge more for altered model...of same size...
Funtana 100x to 125 comes to mind... 100$ increase in price, small changes in model....
#1574
My Feedback: (45)
RE: Venus II
ORIGINAL: kochj
Good points....
I have a EF 78 '' extra gas version that I have to build, and could use in pattern....But I would like to have a pattern specific tool
Good points....
You are also assuming that over multiple production runs that the cost doesn't change. The cost of balsa and other products are constantly going up. Also, you will never be able to produce pattern models in the quantity that you will the 30cc and 50cc planes, so your cost will be higher for that as well.
Arch
