Composite-ARF Integral, kinda build thread
#1001
RE: Composite-ARF Integral, kinda build thread
Joe
I just got mine a few months ago as well.
Lets get this thread going again with the semi retro Intregral, can't be too bad Shulman and Jesky flew them for a long time.
Cheers
Greg
Cheers
Greg
#1002
My Feedback: (8)
Sounds good to me. Every contest I go to, I look at all the planes and pick my favorite - it's always the Integral (unless Dave's Bravo is around). And I fly intermediate, I just need a plane that flies straight. There should be plenty of info in this thread, and others, about what to do and what to change to get a pretty darn good flying airplane.
Did yours come with the silver or clear canopy? There are not many new planes left out there so I bought what I could find - the picture showed the 'old' pic with the clear canopy but I'm not sure what I'll get. Supposedly the silver one is lighter.
#1003
I had a pair of Dave Snow Spark wings on my Integral. Highly recommended! The snaps were considerably more consistent, and the plane picked up quite a bit of speed range. Dave says this was because the top hinged wing on the stock Integral creates a lot of drag.
In the interests of full disclosure, I also had a set of Dave Snow anhedral Stabs as well.
Brenner ...
PS-> You also save a lot of weight over the stock wings too...
Brenner ...
#1004
ORIGINAL: gaRCfield
CARF reduced component weight quite a bit from the original release kits and it is pretty easy to make weight without replacing components if you use a light motor such as Pletty, Neu, Hacker. Flying Intermediate, you don't need big batteries so you can use 44-4500mah batteries and that helps also. My son has an Integral that is under 5K gram limit using a Himax 6330 and Flightmax 5000mah batteries and we didn't replace any components.
Woodie
#1005
Joe
Mine came with silver canopy thankfully, for some reason I don't like clear canopy's on F3A models.
I bought it to power it with Brenner's contra drive but I think there are better airframes for that power system so its just been kinda sitting around.
I currently fly Oxai Austral XX's with YS power and like them a lot.
Not sure what to power the Integral with, I keep changing my mind between an outrunner and IC.
The post from Woodie is encouraging on weight because I thought it might struggle to make weight electric.
I think I'm in a similar class over here to you, just need a true flying machine which my current Austral's are hence I haven't been in a hurry to replace them but I should get cracking on the Integral anyway.
What are you going to power your's with?
Cheers
Greg
Cheers
Greg
#1006
My Feedback: (8)
Well, unfortunately Chief Aircraft was erroneous in telling me they had a plane in stock. I got a call this afternoon saying the plane is unavailable. The Comp Arf rep said the last white one made is already sold. I'm hoping the other rep has on stored in his hobby shop somewhere.
I am pretty good at making things happen, I hope I can continue my luck on this one. An all-white composite ARF for $1000 is really meant for me.
#1007
If I could figure out how to ship it, you could have mine for a grand because I'm clearly undecided on what to do with it.
Cheers
Greg
Cheers
Greg
#1009
MI
Joe,
Bob Kane has one but I'm not sure if he plans on selling it. I sent him an e-mail. BTW, having built 3 of them, I recommend reducing the downthrust to 1/2 degree, adding a half degree of right thrust, set the wing at 1/2 degree positive and leave the stab at 0. I had the CG at about 1/8" behind the LE of the wing tube. With those settings, it's a great flying plane. OTOH, Andrew and Jason had a lot of success flying them box stock and mixing out the anomolies.
Verne
Verne
ORIGINAL: gaRCfield
#1012
My Feedback: (8)
ORIGINAL: gaRCfield
I can't believe... I just ordered an Integral!
Not sure why I can't believe it, I sure have been spending a lot of time at work thinking about it...
I guess I'll be seeing some of you guys in Michigan!!
#1014
My Feedback: (8)
I picked the plane up this weekend - thanks Verne and Bob!
1) I am still undecided about motor selection. I want light weight and reliable. My choices are Plettenberg 25-12 Evo, Neutral F3A, and Hacker C50 (non comp). I do have a Neu 1512 that I can use as a backup if there was ever an issue with the Neu F3A, so down time would be minimal. The Pletty 25 is an 18.4 oz outrunner that meets the required specs, but I don't see a lot of field usage, nor know about service. I imagine the Hacker is reliable and I know about getting it serviced, but if the c50 is enough, why is there a comp version for $300 extra?
2) I'm working through servo selection. Not sure if I want to stay with one brand, or mix Futaba and JR for the lighted possible combination. This may depend on whether or not the 9411 will fit in the ailerons; it will br close as the lite ply is cut close to 1.5in long.
JR has a cored servo that is a direct drop-in in the stab (ds831 i think). It is inexpensive and light but so far, my favorite servos (very smooth feeling) have been coreless. That being said I have little experience with JR (821 only) and no experience with Futaba.
#1015
MI
Joe,
I strongly recommend the Hacker C50-14XL Comp. The non comp versions are prone to overheating resulting in magnet separation. The comp version has a built-in fan that prevents all of that. I bought two of them 8 years ago and still use them today. In fact, those are the only two electric motors I've ever had or needed. With 25C batteries, I never use or need full power.
Verne
Verne
ORIGINAL: gaRCfield
#1016
My Feedback: (25)
ORIGINAL: gaRCfield
I've put together four Integrals, and the elevator servo size in the stab is sized for a mini servo, but the rails are a little long on each side, so they have to be cut back 2-3mm on each rail.
I've used JR since practically day 1, so I can give you a run down of servos that I would recommend.
For a standard regulated setup:
(2) JR DS9411 for ailerons
(2) JR DS3421 or DS3517 for elevator
(1) JR DS 8411 (I've been using this for years and have found no power defecit) for rudder
For an HV setup:
(2) JR DS8411 HV for ailerons
(2) JR DS 3717 HV for elevator
(1) JR DS 8911 for rudder (while many do, we do not endorse running an 8711 on 2S LiPo voltage, and certainly not for the 8411)
My Vanquish has some new JR servos in it...
(2) JR MP91T for ailerons (standard servo case footprint, low profile, ungodly amount of torque, .25oz or so heavier than 9411s)
(2) JR DS3717 for elevator (same as recommended for aforementioned HV setup)
(1) JR MPH81T (linear hall effect sensing servo, again stupid power, wanted to try something new and wanted to run all HV, had access to these)
The micro servo that I presume you are referencing (DS368) while a great servo, is not a good choice for elevators. I used them exclusively on throttle, but they are only a three pole motor and are cored.
I am not overly versed in Futaba's servos, but I believe the standard before the BLS servos came along has been:
(2) 9550 (or 9551s) for ailerons
(2) 9650 for elevators
(1) 9156 on rudder
I hope this helps. Good luck!
#1017
My Feedback: (8)
Thanks guys! I really enjoy and appreciate all the feedback I get here.
I sanded away some if the composite around the servo slots to where the plywood supports start. The 9411 should drop right in. I am going to go with the 8411 on rudder, its a few grams lighter than the Futaba.
So it comes down to the stab. The Futabas are lighter there, and also a lot less expensive. I don't understand the draw to run one brand of servo, but it is there. But the money saved on those servos would afford a new wing tube. I honestly thought it was full of concrete when I took it out of the box, LOL. I guess that foam is pretty dense.
#1018
My Feedback: (8)
What is the best linkage system to use with the stock (phenolic?) control horns?
I was thinking about the carbon rods and titanium ends from Central, but I really prefer a mechanical linkage (not relying on adhesive). It also seems that ball links are not to be used on this type of control horn?
#1019
My Feedback: (46)
NJ
ORIGINAL: gaRCfield
#1020
NY
Hi Joe,
Congratulations on your new plane! For what it's worth, I briefly owned one of the planes built by Ryan and can say without hesitation that he knows how to build one heck of a great Integral and he can be a fantastic resource.
I also wanted to comment on motor selection. I owned 2 Integrals. One built by Ryan with a Pletty 30-10 and one built for JAS with a C50 comp and I know motor selection can be a highly divisive issue around here as I'm sure you are well aware, so I hope you and everyone else reading this will take this as the "one guy's" OPINION and not start a flame war, BUT I really think it comes down to a simple question of do you mind removing and greasing your motor at 50 cycle intervals and what's it worth to you to have a motor that simply won't fail. Personally I have never heard of a Plettenberg 30-10 failing in flight, but I have heard of plenty of Neu and C50 motors failing in flight. When you are dealing with a $3000 investment, I don't understand why you wouldn't choose the "bullet proof" option. I understand the C50 and Neu are more efficient, and that the top FAI flyers are able to discern subtle differences in power application in the mid-range of the throttle curve when comparing an inrunner to an outrunner, but at the level you and I fly I really don't think there is a noticeable difference. Plus if you follow all the advice on this thread, I am certain weight will not be an issue to the point that you need to save 2 ounces on motor selection. Not to mention that if you do a C50 in the ideal fashion with a "soft mount" the total motor weight with mount ends up more than that of a Pletty and a simple firewall mount. Anyways, like I said that's just one dude's opinion and in no way meant to denigrate anyone elses favorite choice
By the way, where are the build pictures????
Joe
Joe
#1021
My Feedback: (8)
Not much for build pics yet, but I do have these
I am trying to: 1) get a plane ready for NATS, and practice, and 2) make room in my tiny house for this big plane (selling my Wind).
I will meet with Bob P. within the next few days to talk about paint and preparation, and I ordered the aileron and rudder servos. I'm not sure if I'll get anything really started before mid June or not, but if I do, there will be pics for sure.
About the motor, well I am trying to build as light as I can. A new C50 comp is just a LOT of money. A Neu is more affordable and also would have a backup motor. There is a lot of data about the Pletty 25-12 but unfortunately not many people flying it.
If ~2oz in the motor is not a big deal, I would likely go with a Hacker A60 or a Himax F3A.
#1022
My Feedback: (8)
OK one more minor hardware question: what are the best axles and tailwheel to use on this plane? The wheels i have are 18mm wide, probably the same as the nuance. So far my only tail wheel experience is the hefty Sullivan rigs. They are nice but I imagine there is better. Obviously want something light, but also robust. I'm sure many of you know the Hebron runway, LOL.
Joe thanks for the advice on linkages. Ill go with clevises on the control horns. I have those Ti rods on my Wind.
#1023
does anybody need a set of composit wings or a slightly dinged Intergral the fuse is cracked in the middle two canopys one black one silver I think the plane could be fixed
#1025
Having had 7 of these built in my garage, there are ways to actually take an Integral from box on Friday afternoon and test fly it on Sunday evening. Mostly, it's installing servos, mounting landing gear/tail wheel, epoxying in horns, firewall and rudder/battery trays in Friday night and then the chin and canopy mounting, servo pushrods/pull-pull Saturday and final rigging on Sunday. Just try to group glue sessions together.
We've done this with all motor set-ups too. YS-160, OS-200, Hacker C-50, Pletty 30-10 and Fury F3A. During the winter the test flight was at dusk, but spring/summer time we had enough time for 3 flights.
