Composite-ARF Integral, kinda build thread
#1028
My Feedback: (46)
NJ
RE: Composite-ARF Integral, kinda build thread
ORIGINAL: gaRCfield
Yeah the process is straight forward. As soon as I have my shop clear and the parts procured, it looks like a fun and fairly quick build. I will probably spend more time trying to decide what axles and tailwheel to use, lol
Use Bolly CF E-landing gear and wheelpants, central hobby aluminum axles, and light 2-3/4" wheels.
#1030
I think the length of the std gear might be an issue for electric and they are super stiff as well, transfer lots of load back into the fuse which doesn't have a lot of reserve strength in the gear area. I got a Graphtech for mine which I think is about an inch longer and much more flexible, I used one on a previous model and it was great.
Cheers
Greg
Cheers
Greg
#1031
FWIW, Joe L just sold two absolutely beautiful, superbly equipped and true flying electric Integrals. Wouldn't hesitate to check out any gear that he suggests for yours. I am still kicking myself for passing on one of these but the timing was not right and I didn't fully appreciate the value offered. Now that I am flying against one of them this season, I see what a fine example it is. Silly sportsman stuff LOL, but parts is parts. Good shopping!
#1032
My Feedback: (8)
ORIGINAL: danamania
ORIGINAL: danamania
FWIW, Joe L just sold two absolutely beautiful, superbly equipped and true flying electric Integrals. I am still kicking myself for passing on one of these but the timing was not right and I didn't fully appreciate the value offered.
#1034
MI
I used the F3A Long on my Integrals, though the F3A Electric would probably be okay. The F3A long are just a little taller than the electric.
Verne
Verne
ORIGINAL: gaRCfield
Aeroproduct.net has ''an exact clone'' of the Bolly F3A electric gear. Verne, thanks for the suggestion - I found it on another page
#1036
My Feedback: (8)
I am giving a lot of thought to the new Hacker Q80. They are claiming 18.9oz (535g) and options of 210kV or 225kV. I am trying to find drawings/dimensions to see if one can fit in the nose of the Integral. I cut out a paper circle the right diameter, but I don't know how far back it has to be. It looks like it may fit. My other 1st choice is the Xtra 30-10. I don't see the need for the Advance - everyone seems to be dialing it back, so why would it be worth the extra oz (for me)?
http://www.hacker-motor-shop.com/e-v...=3&c=476&p=476
#1037
ORIGINAL: gaRCfield
#1038
My Feedback: (8)
ORIGINAL: can773
Advance had better bottom end, more efficient, runs much cooler, mounting is lighter and more rigid, and it will swing a bigger prop than the evo without getting unhappy.
ORIGINAL: gaRCfield
(20min later...) Wow - nose ring mount for the Advance?!?! Easy and light, I like it!! So that or the Hacker, but leaning on the Advance now.
#1039
My Feedback: (8)
I think I am going to use the Secraft aluminum control rods and the bearing clevises from Central Hobbies - can anyone tell me what length control rods I need for ailerons and elevators? I am using JR 9411 in the wings and 3517 in the stabs.
Joe, my favorite prop for the Integral is the Falcon 20.5x14.5. Gives good vertical pull yet has some speed left for those windy days. However, the Advance could use anything from a 20x13 to a 21x14 without issue. It is powerful, runs cool and is very quiet. So, prop choice is very broad for the Advance. I think it is really more a choice of what prop to use with the Integral rather than what the Advance can handle. My Integral seemed 'happier' with a little speed so I stayed in the higher pitch ranges. My Integral was in the 10lb 20oz range depending on battery, if your Integral is lighter, it might be fine at lower speeds. You could start with a 20.5 x 14 APC, see how it feels and then go from there depending on whether you want more speed, more pull, etc.
Woodie
Woodie
#1042
CA
ORIGINAL: woodie
Woodie
Woodie
Hey Woodie, is 10 lb 20 oz same as 11 lb 4 oz? ...
#1043
My Feedback: (8)
Thanks Woodie. I was thinking mostly what's the best prop for the plane (do most people like this plane with a little more speed?) of course different motors run at different RPM so it is a system. But, it sounds like something like a 21x14 is a good place to start.
#1044
ORIGINAL: riot3d
ORIGINAL: woodie
Woodie
Woodie
#1045
CA
ORIGINAL: woodie
yep, of course it is under the 11 lb limit if I report it like that.... ;-)
ORIGINAL: riot3d
ORIGINAL: woodie
Woodie
Woodie
I thought so ...
#1046
MI
I ran the APC 20.5 X 14 on all three I built and had the throttle governed back to make it easier to manage the excess power. That was with the Hacker C50-14XL on 5000mah 20C batteries. I tried the APC 21 X 14 and didn't like it, but don't remember why. This year I switched to an APC 21 X 13.5 to slow things down a little more. The APC 20.5 X 14 was a great prop but could get a little zoomy if you weren't careful with the throttle stick.
Verne
Verne
ORIGINAL: gaRCfield
#1047
My Feedback: (8)
If anyone has their Integral near by, I am looking for a few numbers:
1) What length extension is needed for elevator servos and aileron servos?
2) What size push rods for the elevator and stab surfaces? I have JR servos.
Joe
Joe
#1048
ORIGINAL: gaRCfield
Joe
Joe
is this an electric setup?
#1 would depend on some factors such as what length are the leads on your servos, where you receiver is located and are you using any extensions on the receiver to plug the aileron leads into.
#2 are you using carbon rods, threaded links or some type of turnbuckle?
Woodie
#1049
My Feedback: (8)
ORIGINAL: woodie
Joe,
Woodie
ORIGINAL: gaRCfield
Joe
Joe
Woodie
Yes, electric
1) Not sure of servo lead length other than they are 9411's in the wing and 3517's in the tail. And probably will want leads out of the Rx to plug into.
2) Was thinking Al or Ti turnbuckles (4-40) with bb connectors at servo end and clevis at horn end.
Plane is stuck in my storage facility, so I can't measure the plane or parts, but am trying to get everything together in advance so plane can be built ASAP. I appreciate any help
#1050
GaRCfield
The servos are 14" from the root on my Integral
It's 42" from the middle of the stabs to the location of my receiver located at the beginning of the turtle back
Hope that helps
Hope that helps
