If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 7 of 17 FirstFirst ... 56789 ... LastLast
Results 151 to 175 of 402
  1. #151
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It has been too long!
    But we are back. Please excuse the delay. My girlfriend lives in Germany, and forgiving though she is, she likes to see me in person now and again. So, I took a few days off.
    Anyway, today I returned and started on hinging rudders. Today I will post the steps taken to match the rudders to the fuselages, and then I shall post a little hint of our covering process which I sincerely hope you enjoy.
    Rudder hinging.
    Since the rudders where faced and roughed out with the stabs, all that remained was to hinge and taper into the fuselage. Please refer to the stab hinging segment for a detailed explantion or the hinging process. Nothing changes.
    This first photo shows the rudders aligned with the fin for establishing the hinge locations.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #152
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    All slots cut.
    After cutting the slots with our Tettra guide and recessing the slots for the hinge pin, we mount the rudder to the fuse. Any hinge adjustments are made and the rudder is taped firmly to the fin, hinges in place.
  3. #153
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Now we do the tips.
    The top and bottom of the rudder must blend in with the fuselage, so it is done inplace. I start with 80 grit and go to 240 at this stage. Of course, our final sanding of the wood parts will be with 1000 grit, but that comes a little later.
    Here is the blended top.
  4. #154
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Another angle
    The top from the side.
  5. #155
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ZNLine factory: Enigma Building
    And the bottom. Notice the forward part of the bottom block flattens. This will nicely accept the MK tail wheel steering arm.
  6. #156
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The big picture. Still to be done here to inlay the horn hardpoint pieces and beveling of both the fin and the rudder. After that I can final sand the rudder and it can wait until the fuselage is painted and then it gets covered.
    Speaking of covering, the big chief was cutting the covering for his Enigma, so the next couple of posts I will show you a special tool we use to get "the worlds best covering job".
    First, the rudder.
  7. #157
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It starts with a design.
    Here is a photo of the first Zardini built Enigma. We have a very special friend that creates the designs for our airplanes. Here is his design. The painting is done in Brussels (the painter stands next to me right now).
    The covering is done in Liege. I shall have photos of all of this going on in about four weeks.
    We will use this design on JPs and my airplanes. I still do not know what the others shall have.
  8. #158
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The design is done with Corel Draw.
    Here is a screen shot of one of our covering piece files.
  9. #159
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A close up
    Same screen, just closer.
  10. #160
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How does one cut that?
    While completely possible to cut this by hand by print templates, it comes out with better consistency, accuracy, and much faster when cut by plotter cutter.
    This machine is worth it's weight in gold, or in this case, in Oracover.
  11. #161
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It takes about ten minutes to cut the entire airplane.
    The operator should assist the machine by guiding the roll end. Oracover is not as easy for the machine to feed as the Vinyl rolls, but the end result is just as good as the Vinyl graphics.
    Here is JP making sure that the machine feeds properly. Close inspection of the photo will show the lines on a couple of pieces cut for the Enigma.
  12. #162
    Join Date
    Oct 2002
    lancaster, CA,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Plotter for film covering? Its official - you guys are "high-tech."
    Jim
  13. #163
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    This is what all this is work is leading to.
    Hopefully, in no more than 6 weeks now we will be taking pictures of several of these, one of which will have my name inscribed on the side in vinyl instead of the little piece of masking tape that I use to identify mine.
    I know that these pictures are a little premature, but I hope that you will keep viewing the ZNLine Factory postings.
    Ailerons are coming up soon. For those STILL waiting on the motor, that is actually the last of the construction, so a little while longer.
    Pictured here is our current standard design package. This is the basic scheme that a customer receives when buying an ARF unless they provide their own design. All the graphics, of course, are customer preference. You can have this without graphics, or with any sponsoring graphics or the wife's name, however. Oh, of course colors are the customers preference also.
    On the covering, it is cut for a 2mm overlap at all points. Some of the smaller pieces go directly over covering, but most is 2mm overlap.
    Jim, I never believed it could be like this. It was not so many years ago I was knocking out a SuperSportster on my cork covered door. Oh, I still use that door and I still build regular old plan and pin airplanes. I guess some things will never change.
    Mark
  14. #164
    rajul's Avatar
    Join Date
    Jun 2002
    Missouri City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Re: To answer your questions
    Originally posted by MarkNovack
    We use epoxy resins and hardners from R&G Gmbh. We can order this in small quantities for sale. We order int in 5kg jugs for resin and 1L bottles of hardner. It is a very thin epoxy.
    We use there 24 hour hardner (40:100 mix measures on a gram scale), but they have other times of hardner available.
    Hi Mark, I was browsing R&G's website and they definitely have more variety compared to Ciba Geigy. They specialize in composites and supply all the direct materials needed including vacuum equipment ! May I ask what is the part number of the resin and 24-hr hardener you are using ? Thanks..................Mike
    Mike Marks
    RCU Moderator
    Aerofly Support Representative http://www.aerofly.com/index.html
  15. #165
    Mark,
    Would you care to divulge in the cost of that cutter plotter? I had an idea of using a computer to design color schemes, but that is really neat.
    Ryan Smith
    Team JR | Thunder Power RC
    F3A Unlimited | Castle Creations
  16. #166
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Epoxy and plotters
    Mike,
    The epoxy we use is resin and hardner series L. Searching through R&Gs great handbook, though, will provide many different solutions for glueing. Nice company I think. Lots of fantastic products. On a side note, the Europeans have been using composites for modeling and hobby products when the technology was reserved for the high-tech aircraft industry in the USA, so the availability of products in Europe is fantastic.
    On the hinge question that I missed, the hinges are bulk purchased, but the equivilant would be the standard Robart nylon blade pinned hinge. For this application I would not use hinge points as the facing is to thin to for the points to get a good grip. The nylon hinges provide an absolute sure grip when glued in with the L epoxy mixed with a moderate amount of microballoon.
    Ryan,
    Honestly, I have no idea what the plotter runs and all the chief tells me is "beaucoups", or lots. I'm sure well past the $2000.00 range. It is very fast and the accuracy is perfect.
    JP is currently beveling tail surfaces with the belt sander. Today's postings will detail the beveling, finish facing, TE and hardpoint installation. Exacting work, JP does all the machining personally for an outstanding finished tail. I'll be working on the posts in a few hours after I get the last of the gluing finished.
    Mark
  17. #167
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Things are looking good here.
    What a day. Beveling and milling and routing and cutting and gluing and doing it three times over.
    The day started out by beveling the rudder. JP prefers to use the belt sander. I would like to clarify that this takes extremely experienced hands to machine sand to a perfectly centered bevel and be consistent again and again. It also turns out with perfectly straight lines.
    Most of us mortals, myself included, are better off using a long sanding block. It is very easy to turn a few weeks of work into a pile of toothpicks on the belt.
    Here is JP sanding out the first rudder of the day.
  18. #168
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And the rudder close up
    The bevel is checked and checked until it is just right. This one is just right.
    I did not succed in getting great depth of field on the photo, so only a portion of the bevel is in good focus.
  19. #169
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Next bevel.
    A control surface with too great a bevel angle has no durability on the beveled edge, so in order to get the proper amount of throw, a double bevel is necessary. Here goes the fuselage.
  20. #170
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Half of the bevel.
    It is really difficult to add material at this point, so we work slowly. We check throw for one direction.
  21. #171
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mount the rudder.
    Here JP uses a false square, a tool that is used to equalize angles. There is no gauge on it, but it compares angles super easily. Next he will make the throw for left rudder match the gauge's setting.
  22. #172
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And the left side bevel.
    Flip the fuse and do the other side. Lots of checking on this one.
  23. #173
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And checking both sides
    We want 45 degrees left and right. No more, no less.
  24. #174
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Other side.
  25. #175
    MarkNovack's Avatar
    Join Date
    Feb 2002
    Nameche, BELGIUM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The tool
    Here is the simple tool. This thing can be your best friend, or if used by your boss to check your work, you may start to hide it!!!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
