World Models Spot-On 120
#251
1 Post
RE: World Models Spot-On 120
Woodie, thanks for harsh words to be kind. I'm glad I stuck with it.
see my edit above. initial psot was done in a restaurant with the wife looking rather p*****D off :/
#252
TX
Hello guys:
I really love my Spot-On 120, the only problem I have been having is that the cannopy continuosly brakes. Now I'm ordering the 3rd one. Any suggestions?
Happy Landings
Luis
Happy Landings
Luis
#253
CA
ORIGINAL: pilomeza
Hello guys:
Happy Landings
Luis
Hello guys:
Happy Landings
Luis
Adrian
#254
TX
Hi Adrian:
Yes I feel the material brittle, the first canopy came off on flight because it cracked from one of the screws, the second one during a flight got a big crack also from one of the screws.
In both cases I have secured the canopy with the screws provided by TWM, and double sided tape to seal any gap betwen the fuselage and the canopy and reinforce the screw holes.
Maybe an after market canopy would be better.
What after market canopy did you install?
Thanks for the help
Luis
Thanks for the help
Luis
#255
CA
Luis,
I used a canopy from one of my old 2 meter pattern plane, and trim it to the correct size.
Unfortunately, one of the draw back of a glow engine is vibration, especially a 4 stroke. If you look closely on one of the picture, you can tell I used blue electrical tape to secure the canopy onto the fuselage. Then, fasten the screws on top with a drop of CA. So far, it works. However, if I ever need to replace the canopy, it will be an ugly mess. I think the electrical tape will tore the covering into pieces, but that's another story ...
Adrian
Adrian
#258
Hello everyone,
I am just finishing my SpotOn. I decided to mount a OS120AX.
I'll re-drilling the wall to tilt the motor to tilt and pull the exhaust from below. I put the tank in the center. Is the pump really required?
I'm surprised to see that the CG is so forward. Have you followed the instructions?
Yves
PS: sorry for the syntax I used google translation.
Yves
#259
1 Post
I don't have experience with the 1.20AX and pumps but my Spot On CG is at 175mm from the leading edge. Wing incidence is 0.6¤ and downthruse is 1.2 ¤. It flies well enough.
#260
CA
ORIGINAL: g_mkoch
quick question
Does anyone have a few tips to install the wheel pants? I haven't been able to put the on.
quick question
Try mine if you like, it's on the middle of the page:- http://www.rcuniverse.com/forum/m_58..._4/key_/tm.htm
Hope this helps.
Adrian
#261
1 Post
I mount the wheel pants without the supplied hardware because I am using a different landing gear after the supplied set collapsed on landing 11.
Using a genuine carbon gear now.
Also rebuilt the landing gear plate by sandwiching two sheets of thin ply over a 235gr/m^2 Carbon Kevlar weave.
I've had no landing issues since and dropped thw weight of the fuselage by 18gr (whoop whoop)
