Quique-OXAI announce Euphoria GP biplane
RE: Quique-OXAI announce Euphoria GP biplane
Hi Troy . .
Have you heard anything on the release and price of W. Matt's Amethyst bipe ? Also, the pics I have seen look like EP. Any plans for a GP version?
. . looks a little "radical", but I expect it will be a strong performer.
Jeff
Jeff
No information to share. Sorry
Oxai is pretty tight lipped about things and they like to keep it that way until they debut a model on their website.
This could be just a testing model. Oxai is always testing and building different things. Some see the light of day and some others are just well testing ideas.
This plane is likely something that will get out. The name on the side of the model is Roger Mao. Roger is one of the owners of Oxai. Usually Roger builds the prototype models for the given guy and then keeps one for himself to evaluate as well. These guys do lots of testing and their design process is probably the best of any manufacturer. Then the production folks take the designs and put them to Wood.
Oxai actually has a full time engineer that works on the designs and testing structures and so on. Mr. Yang works hard on the CAD stuff and solid modeling or the projects. Everything is done in CAD all the way down to the color schemes on the models.
Troy
Troy
Is there a possibility of releasing a full equipment listing to get one of these in the air?
I am looking for: Servo model numbers (JR), Pipe being used (eg. Asano) and specifically the linkages being used in this example or are they closely guarded secrets? I am by no means a pattern flyer but would like to outfit a Euphoria within a year's time.
Additionally would like to know when this model will be available for purchase by the general public
Thank you in advance
Chris Hoesel
Chris Hoesel
My Feedback: (20)
As far as equipment lists, the plane is sold airframe only. You need servos, RX, linkages, control horns, fuel tank and tubing, and engine. You obviously have your choice on how to configure it. Troy uses 4 aileron servos, where QQ uses 2 and creates a link from top to bottom wing. Obviously a plane like this deserves the best servo's you can buy, so 2-4 aileron servos, throttle, rudder, and elevator servos. Engine for both is a YS 1.70DZ. Troy uses standard Hatori muffler with a custom header from Central Hobbies that you should be able to get. The airplane is available today. Custom order of course.
#31
Chris,
Try contacting Sam Johnson the US OXAI importer. He can advise you on availability.
Sam Johnson [email protected] / 480-664-1560
#32
My Feedback: (25)
Chris,
There have been a couple different versions of the Euphoria. If you buy one now, you'll likely get the 09 version that has only two aileron servos, versus the four in the prevous version.
For aileron servos on this airplane, go for the 3421SA (and the number of them, either two or four, depends again on what version of the Euphoria you have), 8411SA for the rudder, and I believe an 8611 on the elevator. Both were on pull-pull. YS 1.70DZ, with Asano header and Hatori 821 pipe for power. I'm pretty sure you'll need a K&S tank for it. Quique was running a 1221 at the World's with all of the satellites. I think he ended up using a Duralite LiPo in the last airplane, before he had been using a NiHM pack, I can't remember how big, maybe a 1650? I think QQ used H9 titanium Pro-Links for the ailerons, but he could have used the Central Hobbies carbon pushrod with titanium ends. I'm pretty sure QQ used MK rod ends, either 4-40 or 2.5mm, they're essentially the same size.
That's all I can think of. I hope this helps.
