If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 17 of 17 FirstFirst ... 7151617
Results 401 to 420 of 420
  1. #401
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    Please don't ask me how this one got stuck in my brain last night...
    For old times' sake:
    http://www.youtube.com/watch?v=QHboMLW-Zn0
    Joe Marri
    Enjoying all things aviation.
  2. #402
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    So I got a 3517 servo with all plastic gears. I also got a 3517 servo with metal gears. I think the all plastic gear servo is older, but new. This is for dual elevator servos in my new baby.
    Is there any risk if I regear them with the same gear set, or should I replace the older servo ? I don't want some slight elevator offset to make my plane fly crooked, LOL
    Joe Marri
  3. #403
    RE: Post all your
    Joe,
    Did you buy them new or used? Sounds like one has simply been re-geared; to the best of my recollection, the 3517 has always been a metal gear servo.
    Ryan Smith
    Team JR | Thunder Power RC
    F3A Unlimited | Castle Creations
  4. #404
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    They are both NIP; I think the 3517 started out with nylon gears and over time it got a metal output gear, and finally metal gears. The package is almost identical except for the mg part, and the specs are the same. Should be OK I guess? Not really sure what would happen over time to any components, so hopefully response/speed/etc would be the same.
    http://www.servodatabase.com/servo/jr/ds3517
    Joe Marri
  5. #405
    Join Date
    May 2002
    Pittsburg, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    JR DS3517 actually came out with plastic gear version as Joe mentioned above.
    Later, Metal gear versions came out, but DS3517 standard got discontinued.
    Reason was the heli guys kept on breaking the gears on 3517.
    I have a few of those at home too. Was going to use them on Kyosho Flip, but decided to go with metal gears instead. For use on elevators of Pattern plane should be good.
  6. #406
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    what is the right thickness of carbon plate for making motor mounts? This would be bolted or glued to a nose ring and supported in the rear. Is 1/16" too thin?
    Joe Marri
  7. #407
    woodie's Avatar
    Join Date
    Jun 2002
    Placerville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    While carbon plate is very strong, it isn't the lightest composite around, nor the easiest to cut. I prefer 1/8" end grain balsa/carbon laminate (carbon on both sides. Very strong, fairly easy to cut. If you are using the rear support for the Advance, 1/8" end grain/carbon laminate is plenty strong enough. On my Spark (small diameter nose ring), I only use the 1/8" end grain/carbon laminate with no rear support. No issues so far......
    Woodie
    There is nothing so simple it can't be messed up by someone....
  8. #408
    Join Date
    Sep 2005
    San Jose, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    Don,
    Interesting, I thought that it was standard practice for front mount inrunners to also have a rear support. I know that the Spark hasthe total nose of the plane reinforced withcarbon fiber cloth. Is this the reasonyou can use justa front mount of1/8" balsa/carbon laminate?
    Terry
  9. #409
    woodie's Avatar
    Join Date
    Jun 2002
    Placerville, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    Terry, yes it is common practice to use a rear support for in-runners, however, the Advance (yes, an in-runner) is configured more like an outrunner with a a large base/mounting plate area that goes against the nose ring plate. It is also a small nose ring, the Advance barely fits into the nose so there is not much unsupported area outside the motor mounting plate. The entire nose of the Spark is carbon fibre too.
    After I installed the motor, I gave it the ole 'grab a prop blade and pull hard/twist' test (highly calibrated BTW) and nothing moved so I did not install the rear support.
    I believe the new Angel Shadow is also set up this way.
    Like I said, so far no problems.....
    Woodie
  10. #410
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    I tried the laminated end-grain balsa, had issues with the balsa crushing. I chose carbon to avoid that, to allow for a mount that will be very robust to installing/removing the motor, etc. Even the glassed-ply motor box in my Sebart Wind 110 started to crush a little after many flights and showed signs of fatigue.
    I just bought some 1.5mm and 2mm carbon and have some 2.5mm carbon here. It seems to me that the 'commercially available' G10 and carbon mounts are somewhere between 1.5 and 2mm. It would be nice to get away with the 1.5mm. The Advance will be front- and rear supported.
    http://www.znline.com/photos.php?sou...372463&index=0
    javascriptopupWindow('http://www.f3aunlimited.com/webstore/index.php?main_page=popup_image&pID=193')
    Joe Marri
  11. #411
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    For pull-pull, I am considering the following cable options - would like to hear your thoughts
    1) 7-strand stainless fishing leader, 40lb test, nylon coated
    http://www.afwhiseas.com/product-p/c045b-0.htm
    2) 49-strand stainless 'knotable' fishing leader, 40lb test, nylon coated (super flexible and resistant to memory/kinking)
    http://www.afwhiseas.com/product-p/cm49-40b-a.htm
    3) nylon coated kevlar
    http://www.yourfavorite_kevlarsupplier.com(ic)
    I am nervous about using kevlar - have not used it yet, do not want it to fray/break/creep or whatever - this is my first 2m plane. I do like light weight though!
    Joe Marri
  12. #412
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    My new toy
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Joe Marri
  13. #413
    Join Date
    May 2004
    Whippany, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    ORIGINAL: Ryan Smith
    Joe,
    Ryan,
    Did you get my answer to your questions?
    Regards,
    MattK
  14. #414
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    ORIGINAL: MTK
    Joe,
    Ryan,
    I thought Patternflyer covered it above; they are both new servos but from different sources. One must be older but still in package and has all plastic gears.
    Joe Marri
  15. #415
    Join Date
    Mar 2010
    grand rapids, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    THAT'S going to put you over on weight......won't even ponder the dB penalties either
    Urge Congress to keep common sense in the skies
  16. #416
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    ORIGINAL: corch
    Joe Marri
  17. #417
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    I ran into Dave Brown in the book store the other day. I had my AMA hoodie on so he said something. I just think that's so cool
    Joe Marri
  18. #418
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    Can anyone recommend a good building stand?
    Joe Marri
  19. #419
    Join Date
    May 2004
    Whippany, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    Why did your cross grained balsa crush? Did you not use hard points?
    I use 1/4" x 5/32" carbon tube hard points. The blind nut is mounted on adonut of 1/8" a/c ply and backs up against the carbon tubing.
    I made teflon covered kevlar 10 years ago and am still using this stock today. All cable types need a simple rule followed at the contact points....make sure you round off any hard edges on steel ferrules and threaded rod holes. Kevlar has never failed while ss has....
    Regards,
    MattK
  20. #420
    Jetdesign's Avatar
    Join Date
    May 2008
    Mason, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Post all your
    ORIGINAL: PatternFlyer
    I just went to re-gear the two servos - I got nylon gears for the MG, and a metal output gear for the old 3517. It is easy to remove the nylon output gear, but it leaves behind the bearing and what looks like something else. Don't want to pull to hard - so I put the nylon output gear back on and find it's pretty easy to just spin it around the shaft.
    What holds the gears to the pot shaft??
    Joe Marri
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
