Futaba BLS153 Brushless Mini Air Servo
RE: Futaba BLS153 Brushless Mini Air Servo
The BLS 153 Servo is the successor to the S 9650 Servos, but in the brushless version. With identical dimensions, the torque, keeping the same speed has risen by 35%. The BLS 153 has its mounts designed for vertical installation in the model.
It is designed as a swashplate servo in helicopters up to 1,etre rotor diameter. Or as a wing servo in large model aircraft.
The advantages of Brushless-Motor technology:
# 30% faster Reaction time = better acceleration
# more resistant to shock and vibration
# higher efficiency, lower heat generation
# no brush wear = 5 times motor life
# Special-Gearbox = no backlash
# Samarium-Cobalt magnets
# higher resolution
# same current drain as normal digital servos
# Specifications:
Dimensions: 35,5 x 15 x 28,6 mm
Mass/weight: 30.00 pond/g
Operating voltage: 4,8-6 Volts
Torque: 48.00 Ncm Torque: 61.00 Ncm
Transit speed: 0.11 Sec/45° Transit speed: 0.09 Sec/45°
Holding power: 120.00 Ncm Holding power: 152.00 Ncm
# higher resolution
# Specifications:
is there any test report on those servos ? Very interesting characteristics...
What about using them on the ailerons ?
rémi
rémi
My Feedback: (45)
I was looking on Futaba's site www.futaba-rc.com and noticed those initial specs were a little high. I remembered when I asked a few months ago that the specs weren't quite that impressive. These are the official ones from Futaba.
4.8V 76 oz-in. 0.15 sec/60°
6.0V No information.
Arch
Arch
ORIGINAL: shannah
What's the difference between this and the bls651 that is already on the market?
Also do they have metal gears ??
Brian
Little up for this thread.
It seems that the BLS 153 and BLS 651 are very similar but no many informations about it.
Does anybody have any clarification on the BLS 153 on whether it can use 6v? I bought a couple from Tower and should have them next week, Tower's specs show 6v but I discovered later that Futaba site does NOT show this... anybody with some that can clear this up?
Tom M
Tom M
My Feedback: (45)
ALL Futaba servos will work fine on 6V. Even the ones that specify 4.8 only will work fine on 6V. Only a servo going through a gyro will not work on 6V. I have run many of the 4.8V only servos on 6V and they all work great. The 4.8V only spec was something they came up with in Japan, but I have never had a problem with any of them, including the new brushless servos.
Arch
Arch
