OS 140RX EFI Bearing
RE: OS 140RX EFI Bearing
No, the bearing for the 140EFI is a sealed and pre-greased one. It is an excellent upgrade for a std. 140RX or any other engine that uses the same dimension bearing. After assembly you will find that the engine seems to be harder to turn (more friction), this is normal due to the seals and grease and will not be an issue when running the engine.
