US Nats FAI Update - FINAL RESULTS POSTED
#76
RE: US Nats FAI Update - FINAL RESULTS POSTED
Hans,
I don't know if any of the prototype Neu motors (some of which used the Reisenhauer 6:1 gearbox, the last prototypes were actually done with 6.7:1 P42 gearboxes) were used at the 2009 NATs. There certainly is/was some variation in the power levels of the prototypes. I do know the resulting prop RPM of all the prototypes and production motors is close, so the prototypes using the Reisenhauer would have been slightly lower KV motors compared to the production version.
My motor (w/ P42 6.7:1, manufactured 06/19/09) -
80F
APC 21x14
TP PL V2 5300
CC 85 HV, 2.12 software, medium timing, 12 khz
~82 amps static
~6300 RPM
My backup motor shows the same performance numbers.
Regards,
Dave Lockhart
Team JR, Castle, Neu
[/quote]
Hi Dave I would like to know if the listed users of the Neu in this thread are still using this Reisenauer gearbox (1:6 ratio). And if so does the production version have the same characteristics as what you have seen performing at the Nats or is it a totally different 'animal' . At least the gear ratio seem different.
[/quote]
80F
APC 21x14
TP PL V2 5300
~82 amps static
~6300 RPM
Regards,
Dave Lockhart
[/quote]
[/quote]
#78
Thanks for the info. Doesn't look like electrics need a change in the rules.
Jim
Thanks for the info
Jim
ORIGINAL: DaveL322
Jim,
The top 10 in FAI used 5 Neu F3A, 1 14XL, 1 13XL and 3 YS. I'm not positive about the pack mah and props used...but a rough list is below -
Andrew - Spark, 14XL, TP PL V2
Chip - PassPort, Neu F3A, Neu XP4900
Brett - Euphoria, YS
Mark - Aries 07 w/ SFGs, 13XL, TP PL V2 4350s
Dave - Bravo, Neu F3A, TP PL V2 5300s
Don - Black Magic VF3, YS 170 CDI
Todd - PassPort, Neu F3A, TP PL V2
Mike - Integral, Neu F3A, TP PL V2
AC - Pinnacle, YS
Danny - PassPort, Neu F3A, Tanic 4500, 20.5x14
AND...Masters was won by Tony w/ PassPort/Neu and 5 of the top 8 were electric.
Regards,
Dave
edit - changed TP to Neu for lipos used by Chip
Jim,
AC - Pinnacle, YS
Regards,
Dave
