Comp ARF Valiant
Reply
Old 06-03-2010, 01:08 AM
  #201
sgsterling
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Comp ARF Valiant
Hi Ahmet I had aileron deflection set at 22 degrees with 100% servo ATV 60 degree rotation. I never checked deflections beyond 100% ATV/60 degree rotation. With only 22 degree deflection, that is pretty good mechanical advantage/ force multiplication.
I think Bryan and you correct. The drive train on these 9650 is weak and has slop enough to let some vibration turn into flutter. Very easy to happen around center (I was straight and level, no aileron input when it happened). The forces of a resonant flutter can build very quickly and strip out those small nylon gear.
Live and learn I had heavier duty servos sitting on the bench but was trying to make 5kg. I was planning to order the bls551s after seeing Byron's recommendations on his website the week before. But the 9650s were installed and I was hot to try out the new bird.
Steve
sgsterling is offline
Old 06-03-2010, 01:37 AM
  #202
Jason Arnold
Jason Arnold's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G'day Steve,
A mate down here was using S9650 servos in his electric Cyclone for a number of years. He had them on the ailerons and only one on the elevators using DEPS. He has since switched to the BLS 651. He says the BLS servos have next to zero slop and 7Kg of torque.
It's surprising what you can get away with on an electric. Forget it for glow as the vibration will kill it.... Having said that, I have seen people using the JR equivalent of the S9650 on a YS 1.70 powered model... May have had metal gears though... Not sure I would risk that with a YS.
What did your E-Valiant weight come in at and with what batteries?
Cheers
Jason.
Jason Arnold is offline
Old 06-06-2010, 10:01 PM
  #203
wild 330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My E-Valiant weights 4990grs with 4900 Rhino batteries.
Patricio
wild 330 is offline
Old 06-06-2010, 10:14 PM
  #204
Jason Arnold
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Patricio,
That's a pretty good weight with the Rhinos. Rhinos are typically a good 100 grams heavier than TP or F3A Unlimited 10S packs.
Cheers
Jason.
Old 06-07-2010, 12:32 AM
  #205
wagen017
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: wild 330
Patricio
hello Patricio, could you let us know the exact setup you have used for your Valiant? And did you do anything extra to reduce weight? Your input would be very appriciated!
Volkert
wagen017 is offline
Old 06-08-2010, 12:10 AM
  #206
JAS
JAS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As some of you know I am now flying an Envision. I have my Valiant, ready to fly, and I will still be around to answer whatever questions you have about it. Granted, you have a much better person to ask... the designer Bryan Hebert, but if there is anything that I can help with, let me know. I wish I had flown the Valiant at the last Worlds as now I have a perfectly good airplane sitting on my shelf. Once I figured out (was told) that I went backwards on the CG, and Bryan told me were to balance it at, snaps became predictable, spins and stall turns were cake and anything rolling felt much more locked on. But the Envision is my first design and is flying good as well, so I will be flying it this season.
I have been keeping track of the thread and as far as aileron servos, I personally think that 9650's are too small for the ailerons on any 2M pattern plane, even on electric. Back in 03 at the Poland Worlds, we (our electric team) put together 2 Rhapsody's. One had 9650's on the ailerons, the other 9151's (9551/BL551's weren't around then). The one with the 9151's hands down snapped much better than the one with 9650's. And the ailerons on the Rhapsody weren't as big as the Valiant ailerons. Sorry to see what happened Steve. I'm in love with the BLS551's as the aileron servo of choice (I didn't have any BLS551's when my Valiant was put together).
What did the pushrod set-up look like (from a top view like the pic)? Maybe there was some weird angle that didn't help things either.
JAS is offline
Old 06-10-2010, 10:14 PM
  #207
BERUSTY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Valiant...pretty fine flying model!
One of my fellow club members let me fly the 6th flight on his Plettenberg/Thunder Power PL-II powered Valiant this evening...just as Brett Wickizer said in his flight review posted on Bryan Hebert's website...it is a very fine flying airplane. I have been flying a Hacker C5013XL powered Integral the last year and have been very pleased. The 5 minute flight flew through most of P-11 and liked the snaps, rolls and "feel" of the model very much.
Bryan...you done good!
Rusty Dose
Team Futaba
BERUSTY is offline
Old 06-10-2010, 11:18 PM
  #208
flyncajun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Rusty !
I`m glad you had a chance to fly it!
Bryan
flyncajun is offline
Old 06-11-2010, 01:38 PM
  #209
kirkj
My Feedback: (61)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: JAS
Jason,
Can you tell me which motor you used in your Valiant? and prop?
thanks in advance.
kirkj is offline
Old 06-12-2010, 01:29 AM
  #210
pattratt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kirk
Most people on glow are using a YS DZ 170 CDI with an APC 19x11. That is the set up I use and what Bryan uses.
Dick Mundee
pattratt is offline
Old 06-12-2010, 04:19 PM
  #211
JAS
JAS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kirk,
I'm running a 21x14 APC-E on mine, sometimes a 20.5x14 if I want to speed things up a bit. I'm using the Pletty and Fury motors in it (Fury testing, Pletty comps).
JAS is offline
Old 06-12-2010, 06:11 PM
  #212
Jason Arnold
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jason,
What's happening with your F3A Fury motor anyway? Been in testing for quite a while now.
Cheers
Jason.
Old 06-12-2010, 08:01 PM
  #213
wild 330
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello,
sorry for the delay, I ve been out for work.
Tomorrow I´ll take some pictures to my setup .
Patricio.
wild 330 is offline
Old 06-12-2010, 10:42 PM
  #214
JAS
JAS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made a design change to the nose and got 2 different protos for testing and I would like to make one more change but I think the manufacturer is busy with other projects
JAS is offline
Old 11-09-2010, 03:42 PM
  #215
wagen017
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am now in the process of building up a Valiant (JS scheme) and sofar am extremely happy with the build! No issues at all.
It will be electric and I am awaiting news from Plettenberg to decide if I go for the Advanced 30-10. The only problem sofar is I guess that I am building faster then release of this motor. Hopefully we will hear something soon.
Volkert
wagen017 is offline
Old 11-09-2010, 05:23 PM
  #216
serious power
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
How are you for weight with this ?.
Brian
serious power is offline
Old 11-09-2010, 05:59 PM
  #217
pattratt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If anyone is interested, I have a Shulman scheme Valiant and two 170 CDI's available for pickup in Houston Tx area.
If interested send PM.
Dick Mundee
pattratt is offline
Old 11-10-2010, 02:22 AM
  #218
wagen017
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: serious power
Hi,
Brian
Good question! I am building it to be below 5kg. Will see how it comes out.
Volkert
wagen017 is offline
Old 11-10-2010, 10:44 PM
  #219
pattratt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Volkert
The Valiant is a great flying aircraft and you will not have any trouble weight wise even flying a YS CDI.
Set the c/g 1/4 inch in front of the center of the wing tube and trim from there. I would also recommend the use of the strake.
Regards
Dick
pattratt is offline
Old 11-12-2010, 03:04 PM
  #220
Tangy Tom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone have the spinner size of the Valiant? It was mentioned in one of these threads that the diameter was 3 1/4" but CARF are telling me it is 3 1/2"?
Thanks.
Tangy Tom is offline
Old 11-12-2010, 03:20 PM
  #221
pattratt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tangy Tom
I used a TruTurn 3 1/4 FAI. It's not perfect but very close. I don't think TruTurn makes a 3 1/2 FAI.
Dick
pattratt is offline
Old 11-12-2010, 03:34 PM
  #222
Stuart Chale
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Tangy Tom
Does anyone have the spinner size of the Valiant? It was mentioned in one of these threads that the diameter was 3 1/4'' but CARF are telling me it is 3 1/2''?
Thanks.
Post number 39 this thread 3 1/4"
Fits pretty well.
Stuart
Stuart Chale is offline
Old 11-12-2010, 03:39 PM
  #223
wagen017
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BTW Stuart thanks for your build thread, really good and helpful.
Volkert
wagen017 is offline
Old 11-12-2010, 03:49 PM
  #224
Tangy Tom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Stuart,
3 1/4" it is.
Thanks.
Old 12-15-2010, 12:53 PM
  #225
wagen017
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well, my fellow Valiant owners, I am almost at the end of the build. All I wait for now is motor and controller to complete the plane.
I have one question: in the bag of small parts is one carbon rod (6 inch long, 1/4'' OD) and four short pieces of carbon tube (1 inch long, 1/4'' ID, 5/16'' OD). In the booklet I don't see where you should use them, either in the thread here. Any clue what it is supposed to do?
Volkert
wagen017 is offline
