Valiant By Bryan Hebert (First Flight)
#52
CA
RE: Valiant By Bryan Hebert (First Flight)
ORIGINAL: pattratt
I have everything I need to get the acc. I need except the info on the YS mount. I like the looks of the mount design assuming it can be mounted in the Valiant and is not to heavey!
The engine arrived today.
Dick
Dick
What kind of info do you need for the YS mount? I have been using the mount for over 6 years ever since the 160 DZ first came out. IMHO, it is one of the best engine mount on the market. It reduces both noise & vibration, the only maintenance required is to refill the shock absorber periodically with Tamiya oil.
However, you do need a rail/ beam type platform on the engine compartment for the mount installation. In addition, there are two types of mount, type 1 for the 140/ 160 which I believe it's no longer available, and type 2 for the 170 which has a stronger rear mount assembly.
Hope this helps.
Adrian
#53
Arch
Thanks for the reply.
I found out there is a local shop that carries Cool Power but not the heli LS. I am going to talk to them about a quanity discount! Can't hurt to ask. There is a couple of guys who use it but they are "sponsored!" I bought a case thru Tower and it was $45.75 a gallon which I find "outrageous!!" I guess that's what happens when you get OLD!!!
#54
Adrian
If you have been following this thread you know I have ordered Bryans new Valiant. It comes with a firewall mount former that is not installed. I needed to find out if it would be practical to convert the Valiant to a beam mount. If it can be, the only other issue would be a comparision of weight between the the two mounts. Bryan indicated an all up weight of 10.5 lbs with the YS 170 DZ CDI and a hyde mount. That means I don't have much room for additional weight. You said you had been using one for several years, were these aircraft designed with beam mounts or did you have to modify them. I believe Mike Harrision is also using this mount.
Thanks in advance fo any help on this.
Dick
Dick
#55
CA
Dick,
Attached pix of one of my plane with the build-in beam to accommodate the YS mount. As for my other planes, since they do not have the beams, I'm using one of my friend's specially designed firewall bracket for the mount attachment.
You can definitely build the U shape beam yourself with ply & laminated with carbon fiber & attach it to the firewall. However, it takes time and adds weight. Therefore, it will definitely be easier to use the Hyde mount. Besides, there is absolutely nothing wrong with the Hyde.
Adrian
Adrian
#58
ORIGINAL: pattratt
Arch
I found out there is a local shop that carries Cool Power but not the heli LS. I am going to talk to them about a quanity discount! Can't hurt to ask. There is a couple of guys who use it but they are ''sponsored!'' I bought a case thru Tower and it was $45.75 a gallon which I find ''outrageous!!'' I guess that's what happens when you get OLD!!!
Arch
Volkert
PS: and a YS170 900$....
