Mystic (new for 2010)
After several months of building plugs and making molds (I'll never Learn ) I was able to lay up a fuse of my new design "Mystic" that will be built as an electric.
I tried a new material (to me) called a laminate bulker to see how it would work compared to the balsa laminate fuses I have been making (of the Defiant).
It was a lot less work and not bad to work with, but unfortunately came out about 5oz to heavy (main fuse weights 26.5oz excluding canopy and cowl. Anyway time to tool up for a balsa laminate!
Sure wish herex foam was available here in the States. [] Below are some pics.
Todd Schmidt
Todd Schmidt
RE: Mystic (new for 2010)
Thanks Andy, Rune and Vicente for your comments, the fact you like what you see so far helps me stay motivated.
Hey Ryan, we'll have to see how it goes, but more than likely would offer some for sale in the future.
Chris, the plane could be built for glow or electric, however I would need to redesign the chin cowl to accomodate glow. That wouldn't take to much time and effort to do.
Thanks again everyone, once I get a lighter fuse layed up in a week or two I will start a build thread for those who are interested.
Todd
Todd
TX
Todd, you've done it again!!! I just love the lines of the planes you design!
Beautiful work on the cheek cowls and I like the streamlined chin.
Only suggestion, if you ever do another mold , ANDyou are comfortable with an electric only design, extend the canopy opening to the nose so you don't have to have a separate piece for the chin. This would reduce weight and make it easier to build. Of course, this would completely rule out a glow option.
Again,BEAUTIFUL!!!
Keith B
Again,BEAUTIFUL!!!
Keith B
Hi Todd,
I'm pretty sure that Rohacell is available in the US, I saw it listed by one of the composite suppliers while looking for carbon cloth but I don't remember who.
It's available in different densities ,the lighter one being similar in compression to herex.
Its lighter and its white so gives a nice clean finish.
Its more expensive but in terms of the cost of a one off pattern model its not an issue.
Brian
Brian
My Feedback: (58)
TN
Here are some sources in the states
http://www.cstsales.com/rohacell-ss2.html
http://www.cstsales.com/core_materials-ss2.html
http://www.compositesworld.com/suppl....aspx?lcode=ml
scott
scott
Hey Brian, good to hear from you and thanks for your comments The fuse isn't good enough to sell so I don't know what will happen to it.
Thanks for the info Brian and Scott. Rohcell is available and I have considered it. I've only been able to find it in 48" lengths which isn't long enough. Joe Dunnaway informed me of Airex foam so I've contacted a source and am waiting for a reply back.
Thanks Robert for your comments, I hope to see more of you this coming season, are you going to be able to make some contest this year?
Hey Keith, thanks for your comments also. Unfortunately I started the plug for this design before I decided to go electric. I agree with your suggestions, maybe in the future a new set of molds with the suggested mods can be made.
gaRCfield, I've not made a decision on the wing, but will probably go with a thinner airfoil (11% maybe). I'll keep the thread going and will let you know okay.
Todd
Todd
OK
Nice looking fuselage Todd....You probably could sell it to Joe.... With that new wing solution he's playing with, a little bit of a heavy fuse should be "no problem". Looks like you've got another pretty design going...will the wings/stab be like the Def2?
take care....
take care....
Hey Chris,
If you go back to the begining of the old Defiant thread, there's a few pics of the mold building process. If you have any questions or need information on mold building I'd be happy to share how I make molds with you.
Thanks Mark for your comments, hope everything is good with you and your designs..
Hey Chris, not sure what wing planform I'm going to use. Still need to work that out. Are you going to be able to have your Defiant ready for this season?
Todd
Todd
Finally getting some work done on the Mystic. The table top building jig has been nice as it can be adjusted for level and locks the fuse in while all the set up work is being done.
Todd
Todd
