Japanese F3A Championship in Kurobe
RE: Japanese F3A Championship in Kurobe
ORIGINAL: EHFAI
Looks like he may have replaced the gearbox with a belt drive. Would be as quiet as an outie.
ORIGINAL: MTK
Potentially lower maintenance too, as long as alignment holds. Can't tell from the photo if the motor is driving the large sprocket or if the large sprocket is being driven by the belt. The prop looks smaller so it may be the latter
ORIGINAL: EHFAI
Undoubtely the system develops more torque and less rpm; so he can choose to use more pitch or more diameter.
I made some numbers for gearboxes and the first result indicates me that a 50% rpm gives a gearbox in no less than 800 g. This system is for sure less than that.
I suspect that we will see that solution more ofetn from now.
Seems that everybody was impresed with Akiba flying style, very slow and close. Another picture of his Hacker motor development.
ORIGINAL: Ricardo M.
Seriously, this is good stuff. Anybody know what prop size was run?
#31
Unfortunately I have no idea about the prop Mr.Akiba use. But I am hearing merits of this system from my friend who relate to Mr. Akiba. This system is less friction, more silent than its gear down. Besides, it is easy to maintain. Deceleration ratio seems as same as Hacker's gear down.
sarashina
sarashina
#32
Simply scaling the relative diameters of the toothed pulleys as seen in the near side view above gives me 40/15.5mm or 2.58:1
Overall ratio is 2.58 x 2.58 or 6.6:1 ie within limits of this crude measurement the same as 6.7:1 for the standard gearbox.
Malcolm
Malcolm
#33
ORIGINAL: sarashina
sarashina
sarashina
#34
I guess Hacker will not prepare the belt reduction system you think. Mr. Akiba acquired the motor without a gear box and a pinion gear, and then he personally made this unit.
sarashina
sarashina
