RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Pattern Flying (http://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   YS1.60 POWERED IMPACT (http://www.rcuniverse.com/forum/rc-pattern-flying-101/11301351-ys1-60-powered-impact.html)
DAVE KEPHART 11-18-2012 07:54 AM
I HAVE A YS 1.60 IN AN IMPACT.(ITS FOR PRACTICE WHILE I FINISH AN ELECTRIC VANQUISH).THE QUESTION I HAVE IS ,WHAT FUEL?AND WHAT PROP?
jetmech43 11-18-2012 08:49 AM
RE: YS1.60 POWERED IMPACT
18.1-10apc 30% seems the norm
mtcarey 11-18-2012 10:52 AM
Yes that will work fine
riot3d 11-18-2012 03:12 PM
I had the same set up a number of years ago, I used 17x12 wide with Coolpower 30% heli.
Adrian
apereira 11-18-2012 04:39 PM
Also 17x12 30%, I then moved to 17x13, but the engine has to be well broken in and adjusted for that prop, I was very happy with the 17x13.
drac1 11-19-2012 05:08 PM
30% nitro and APC 16.5 X 12. This a very good combination.
Regards
Scott
PeterP 11-19-2012 05:47 PM
I am currently flying a YS160 powered impact and the most important issue is to not load the engine with a big prop. The engine runs best when it is propped to rev at 8200-8400 on the ground. I fly the F3A schedules with this model an I find a 18.1 x 10.1 trimmed to 17.75x10.1 a good setup as this modelis fairly slippery in the air. This setup gives you a little more time, contant speed and better downline breaking. I would suggest a prop with more pitch therefore a higher speed envolope for lower classes 16.5 x 12.5 works well in this instance.
drac1 11-19-2012 07:16 PM
The 16.5 X 12 gives 8200rpm on 30%.
Regards
Scott
