2.4GHz receiver antenna and battery
Reply
Old 11-09-2010, 07:29 PM
WRX Dave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 2.4GHz receiver antenna and battery
Just picked up an Aurora 9. Installing a receiver in an EDF, and directions say to mount the receiver antenna away from the battery. Does anyone know just how far away it has to be, and if it's OK for the antenna to cross itself in at any point?
WRX Dave is offline
Old 11-09-2010, 11:54 PM
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 2.4GHz receiver antenna and battery
ORIGINAL: WRX Dave
WRXDave,
The antenna does not have to be a specific distance away fom the beattery or batteries.
It can be any distance more than 3 inches and preferably above so that in most normal maneuvers the antenna can see 360 degrees all around.
If you have a satellite receiver place the satellite antenna at least 2 inhces away from the primary antenna and at 90 degrees (orno more than 30 degrees off from 90) from the primary.
I wish I would understand what you mean in the green text above. You have the word "antenna" to the singular (only one antenna) and I cannot see how a single antenna can cross itself in at any point.
We are trying to help.
Zor
Zor is offline
Old 11-10-2010, 04:08 AM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: WRX Dave Just picked up an Aurora 9. Installing a receiver in an EDF, and directions say to mount the receiver antenna away from the battery. Does anyone know just how far away it has to be, and if it's OK for the antenna to cross itself in at any point?
Best as far as possible but in my Twinjet, thetip whiskeris inside the model,within 18 mm of the battery, no ill effects noticed to date.
Optima Transceiver (RX) - Installation RX, BODA Antenna & Range Test Results
and more at
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
