Battery for Eclipse 7 / Spectra module ??
I understand the battery charge with the Spectra module drops off faster than a regular TX with a crystal. What are you guys using or recomending??
Banned
I put a nimh high capacity in mine...I charge both and use the nimh primarily which lasts much longer and leave the nicad from the original system as a backup if needed although the nimh has yet to run out...think it's a 1650mah...make sure you get it with the eclipse connector.
