Corona RP4S1 reciever operation voltage
Reply
Old 11-13-2010, 12:07 PM
wesrcfreak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Corona RP4S1 reciever operation voltage
Hello,
Does anyone know if this receiver works on one single lipo cell of 3,7volts?
I know the manual says Voltage 4.8V ~ 6.0VDC.
But maybe someone has already tried it on 1S lipo cell?
This isq the reciever: http://www.hobbyking.com/hobbyking/s...idProduct=5785
Thanks.
Regards Wes.
wesrcfreak is offline
Old 11-13-2010, 01:48 PM
coriolan
coriolan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Corona RP4S1 reciever operation voltage
I use this model in one cell planes and it work Ok down to 3V(same with GWS Pico). Don't know about the synthetized version,but it would cost nothing to try it!
http://www.bphobbies.com/view.asp?id...A3067642&img=l
coriolan is offline
Old 11-13-2010, 02:58 PM
wcmorrison
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know, that is pretty close to brown out voltage to begin with.  A heavy pull on the battery, like an extreme manuever causing several servos to pull at the same time might draw the voltage below cut off and you would lose the receiver.  I would be inclined to use two batteries and see if the system would tolerate 7.4 volts to start with, it so then go that way and not worry about the potential for a brown out.
But then it is your system and you can do what you want.
Chip
wcmorrison is offline
Old 11-13-2010, 03:38 PM
wesrcfreak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hope the power is enough.
I do not think the servo's draw much current.
IT IS FOR AN AIRCRAFT OF MICRO 40 GRAM.
This is my setup I wanna buy.
Servo rudder/elevator: HobbyKing Online R/C Hobby Store : HobbyKing Ultra Micro Servo 1.7g for 3D Flight (Left)
Servo ailerons:HobbyKing Online R/C Hobby Store : HK-282 Ultra-Micro Servo 2.2g / 0.2kg / 0.08sec
Corona recieverr: HobbyKing Online R/C Hobby Store : Corona Synthesized Receiver 4Ch 35Mhz (v2)
Motor: HobbyKing Online R/C Hobby Store : AD-C5 Micro Motor 4.6g Weight 3700Kv
escr:HobbyKing Online R/C Hobby Store : HobbyKing XP 3A 1S 0.7g Brushless Speed Controller
Batt.: HobbyKing Online R/C Hobby Store : Turnigy 138mAh 1S 10C (Kyosho, E-flite, Parkzone Etc)
wire batt. esc: HobbyKing Online R/C Hobby Store : Mini Plug Extention for Micro Battery 10cm (5pcs/bag)
Hope it's work.
Regards Wes.
Old 11-14-2010, 02:01 PM
wesrcfreak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nobody more using this reciever on 1cell lipo??
Regards Wes.
Old 06-05-2012, 07:30 AM
rcmodelland
My Feedback: (14)
rcmodelland's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you need connect the ubec on the receiver, it can fixed the input voltage for the corona receiver.
http://www.rcecho.com/Corona-RP4S1-4...-Receiver.html
rcmodelland is offline
