Modifying Futaba 6ex to Fly- Dream 2.4GHz
Reply
Old 11-23-2010, 12:44 AM
idazhaohui
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Modifying Futaba 6ex to Fly- Dream 2.4GHz
I used Fly-Dreams 2.4G V3 version DIY, it is modular, modified easily, and add positive and negative pulse, no matter what remote, as long as it is PPM ,generally can be modified. >>I want to share it with everyone.
Modified steps:
1Install the operating panel
The panel consists of two push-button switches and an LED. One switch is for Bind Mode. The other is for low-power Range Test Mode. The LED is red and green.
2, Find a place for the DIY Module
A good location is often under the RF circuit board
3,
Solder the three wires to the transmitter circuit board
Finding the PPM signal is sometimes difficult, but often another hobbyist has already done it for you. Search the Internet to find module installations for your transmitter or contact Fly Dream technicians for help.
The module will operate on 6-18 volts. Generally positive battery voltage is easy to find, for example at the switch. Ground is available at many points on the circuit board and generally uses a black wire.>>
4
, Assemble, inspect and test. >>
If you have questions,contact me .
The pictures show a Futaba 6EX modified with a Fly Dream DIY Module
location of operation panel fixed
location of operation panel fixed>>
location of DIY fixed
DIY back onto the Velcro
location three line
Internal overview
Original power RF version removed
photo IS-4R and 6ex after modifying
Compact DIY
idazhaohui is offline
