hs 81 vs dymond d200
Reply
Old 12-01-2010, 11:08 AM
kerwin50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default hs 81 vs dymond d200
I have a dymond 40 size tigermoth. I had dymond d 200 servos in the wing and 1 of them went bad and I noticed that the hs 81 has the same torque specs as the d200.
I'm wondering if it would be ok as I hate to have to buy a mini servo.
The dymond is a tad bit bigger.
the tigermoth only has 2 ailerons but I have a st 45 on her.
In the past the d200 seemed to work fine.
I can't run standard servo's due to the small wing pocket
kerwin50 is offline
Old 12-01-2010, 12:43 PM
Pippin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: hs 81 vs dymond d200
I had both types of servos in some electric planes. The HS81 does not deliver the centring I need. The D200 falls short in resolution and gear strength. Guess. I don't use them anymore.
Pippin is offline
Old 12-01-2010, 01:19 PM
Hauling-A
My Feedback: (7)
Hauling-A's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Hitec HS-85BB is about the same size as the HS81, but is a better servo. It does cost about Five Dollars more than a HS-81, but is well worth it.
J
Hited HS-85BB Servo Specs.
Modulation: Analog
Torque: 4.8V:41.6 oz-in (3.00 kg-cm)
6.0V:48.6 oz-in (3.50 kg-cm)
Speed: 4.8V:0.16 sec/60°
6.0V:0.14 sec/60°
Weight: 0.68 oz (19.2 g)
Dimensions: Length:1.14 in (29.0 mm)
Width:0.51 in (13.0 mm)
Height:1.18 in (30.0 mm)
Motor Type: 3-pole
Gear Type: Plastic
Rotation/Support: Single Bearing
Hauling-A is offline
Old 12-05-2010, 03:51 AM
Pippin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It still offers the same disappointing Dead Band Width of 8usec. I would get the HS-5085MG if it has to be Hitec.
Pippin is offline
