is a Mini servo drawing more amps?
Reply
Old 12-04-2010, 03:30 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default is a Mini servo drawing more amps?
hi,
i'll be using 2 mini-sevos for a V tail and each needs a 3' lead. Is it ok to use the smaller servo wire?
i remember reading something about mini servos drawing more current than a standard one, is it true?
thanks
V.
vasek is offline
Old 12-04-2010, 06:05 AM
JNorton
JNorton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: is a Mini servo drawing more amps?
Servo amperage draw is based in the motor and gear train characteristics not the case size. For a 3 foot extension I'd use a good quality extension using at least 22 gage. You want good quality connections and low resistance, the best in this case. The weight difference is negligible.
John
JNorton is online now
Old 12-05-2010, 02:36 AM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: vasek hi, i'll be using 2 mini-sevos for a V tail and each needs a 3' lead. Is it ok to use the smaller servo wire? i remember reading something about mini servos drawing more current than a standard one, is it true? thanks V.
As in post #2.
Typically the cheaper the servo, the cheaper the motor/gear train and the higher the overall current draw, especially under stress.
Good graphicexamples shown at:
Servo - Database + Download Winzip Program "Choisir ces servos"
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
Old 12-05-2010, 11:05 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good read! thanks Alan
vasek is offline
Old 12-11-2010, 04:34 AM
scribble
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was curious the other day so i checked the amp draw on several servos at the shop. I tried everyting in Hitec's areay that would be used by r/c usage. I started with the HS-55 up to the new High voltage digitals. The meter read at idle from 0.06 up to 0.6 amps at full movement back and forth with no resistance on them.
scribble is offline
Old 12-11-2010, 05:27 AM
JNorton
JNorton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scribble,
Be more useful an indicator if the servos were doing work. No load characteristics don't correspnd to how we use the servos in flight conditions. Glad you were curious enough to grab a meter and check.
John
