Genie screw drive lube for servos
Reply
Old 12-24-2010, 10:53 AM
tacx
tacx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Genie screw drive lube for servos
Hi All,
Got some used Futaba servos. Opened them up and would like to add some lube to the gears and shafts. I was wondering if anyone knows what makes up "Genie garage door screw drive lubricant"? Can't find any info online. Does anyone know it's make up or have used it before. Worried about the plastic gears. The older tubes of Genie lube were called "Lubriplate" which many of you have said you used. But, the newer tubes do not indicate "Lubriplate".
Tom
tacx is offline
Old 12-24-2010, 02:03 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Genie screw drive lube for servos
ORIGINAL: tacx Hi All, Got some used Futaba servos. Opened them up and would like to add some lube to the gears and shafts. I was wondering if anyone knows what makes up "Genie garage door screw drive lubricant"? Can't find any info online. Does anyone know it's make up or have used it before. Worried about the plastic gears. The older tubes of Genie lube were called "Lubriplate" which many of you have said you used. But, the newer tubes do not indicate "Lubriplate". Thanks Tom
That particular product unknown but be guided by:
Servo - DIY Repair - Lubrication (servo grease)
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
Old 12-25-2010, 07:12 AM
LesUyeda
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lubriplate was a stuff I remember lubricating some of the high wear stuff on the WWII M-1 rifle I used to carry. I would not recomment it on servos, it tends to harden up with age were it is not excersized. The recommended stuff these days is silicon grease.
Les
LesUyeda is offline
Old 12-25-2010, 10:41 AM
Four Stroker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try SuperLube silicone grease with PTFE available at ACE hardware and rumored to be at Walmart.
Four Stroker is offline
Old 12-25-2010, 12:57 PM
onewasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tom,
Make it easy on yourself.
Available at most Hobby Shops everywhere !!!!!
http://www.tamiyausa.com/product/ite...oduct-id=87099
A lifetime supply.
onewasp is offline
Old 12-25-2010, 02:38 PM
Zor
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Servos do not really need any lubrication.
But in the same line of thinking I have used a dab of white petroleum jelly USP on the output shaft and the pinion driving the last gear on the output shaft; nowhere else.
It never did any harm. It made me feel better justified or not.
Happy New Year
Zor
Zor is offline
