JR X9303 Doesnt Turn On
Banned
RE: JR X9303 Doesnt Turn On
ORIGINAL: emrecozel
Thanks for ur helping
I live in Turkey right now. So no this is not antenna connection. This is behind the lcd screen and all cable plugs this board.I touch the bottom of the main board and it was too hot.
ORIGINAL: Zor
Somequestions ____ trying to help you.
Where do you live now that you cannot send you radio to the service center ?
What do you call "the main board" ? The one with the antenna connectionnearer to transmitter top ?
or the board nearer the bottom of the case ?
Where about did you touch the main board that it was so hot "you could not keep your finger on more than one second " ???
Did you touch the main board many places ? Like near top ?, bottom ?, near right edge ? near left edge ? You are obviously looking from the back with the back cover open.
Zor
ORIGINAL: emrecozel
Hello, thanks for your help. There is nothing wrong with the battery. I checked it with another battery. So I used to live in New York and i didnt change it.Thats why. This is not batterry or fuse problem. I tried.
Zor
The situation as we can imagine it from the details available could be explained by a shorton tjhe board very close or right at the battery connection .
The boad can be able to dissipate the heat and the amount of short circuit current could be limited by the battery condition. The capability of the battery to deliver a short circuit current.
There could be for example an electrolytic filter capacitorin contact with the board very close to the battery connector that has shorted . It might present a near dead short but not so fully dead short allowing enough current to heat up locally.
Unfortunately it was not said if other parts of the board has been touched to see if it is (was) hot.
It is unikely that the whole board is or get hot..
It is always difficult to diagnoze a problem when the questions we askare not fully answered like in this case.
What I am speculating might take place on the board before the fuse. The short circuit current would not be flowing through the fuse.
Have a REAL GOOD LOOK around where the battery connects to the board. and ____
best of luck.
Zor
Banned
emrecozel
Three weeks have gone by _ _ _
Sure looks like there migh be a short on that PC board near where the power plug from the battery is located.
Did you find anything ?
What is your situation now ?
Zor
