JR Trmtr. Snap Roll Switches & additions
I have a JR DSX9 that I am setting up for my New IMAC Extreme Flight Extra 300 125" I have been setting up the Snap Roll section of the Tranny and want to add full throttle when snap switch is activated. So far I have been able to add a mixin parallelbut when used the throttle stays full on untill I use the snap switch again, which brings the throttle back to the stick setting. ANYIDEARSOUTTHERE. NOTE this is just an idear I had to reduce the work load on vertical snaps.
AB, CANADA
RE: JR Trmtr. Snap Roll Switches & additions
Mix throtle to throtle, activated by the snap switch. This would be similare to my mix as a full stop throtle as a kill, or safety.
I only have a XP9303, and a X9503 here in north america. Realizing your DSX9 is similar, but not identical.
Hope this helps.
-Snuts-
Hope this helps.
-Snuts-
