DX5e
RE: DX5e
All you need is 4 channels to fly a plane like that. It is a Full Range system. It only has an Elevon Mix (for Delta Wings), so you would need to use a Y Harness to connect the Aileron servos together.
Channels are Throttle (Ch1), Aileron (Ch2), Elevator (Ch3), Rudder (Ch4), Gear (Ch5)
MI
RE: DX5e
Yes it is a big deal, but thats not what you asked. Can you fly that plane with a AR500? Yes you can. Can you do aerobatic manuvers? Depends how good you are. All the features you get with a computerized radio make it much easier to control your plane to your liking.
RE: DX5e
ORIGINAL: airmanthesixth
So, you think that not having exponential and all those fancy things is not a big deal even when is an aerobatic plane!
The OP just asked if it was possible to fly the plane with his radio and I said yes
