Pitch Servo problem
Reply
Old 08-06-2003, 10:12 PM
AAC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pitch Servo problem
I have just finished building my Raptor installed all radio gear servo's etc. I then programed the pitch curve & throttle curve values from the raptor instructions. everything seems to work fine except the pitch servo. It is in the neutral position which lines up with the hover mark on the side frame. When i push the throttle stick up or down to line the up with the other markers the servo is not giving enough travel to accomplish this. i have adjusted the ATV's to the maximum of 140% still not enough travel to line up with the 11 degree & -2 degree marks on the raptor. Anyone any suggestions ? adjusting the pushrod just messes everything up !
AAC is offline
Old 08-07-2003, 12:57 AM
Gone to a Higher Plane
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might have better luck getting a responce if you post this in the heli forum. Try the link below.
http://www.rcuniverse.com/forumdispl...s=&forumid=180
Gone to a Higher Plane is offline
Old 08-11-2003, 08:06 AM
Kenneth99
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
shorten the linkage between the servo and the pitch "arm". The distance, center to center of the linkage arm between the eyelets should be about 57mm (according to the manual).
Kenneth99 is offline
