AR6000 QUESTIONS.
SC
AR6000 QUESTIONS.
Hello all,
I just took this rx out from an old plane to put into my new park flyer and I noticed this is no longer made by HH. I have two questions:
1. Is it still safe to fly with this rx?
2. The front plastic shell case came off exposing the circuit board. Do I need to reglue this or is it OK being exposed like this?
Thanks all! DP
Thanks all! DP
RE: AR6000 QUESTIONS.
ORIGINAL: Dai Phan
Hello all,
Thanks all! DP
Hello all,
Thanks all! DP
It will only work with Tx's that are compatible with DSM.
It is a short range receiver good for park flyers.
You should either glue or tape the case back together.
