DX6i V tai and spoileron mix help
what is the setup for DX6i and 6ch Rx to have Spoilerons and V tail mix?
more precisely what channel to plug the 2 ailerons servos and the 2 V tail servos?
thanks
thanks
RE: DX6i V tai and spoileron mix help
ORIGINAL: vasek
thanks
thanks
Choosing the Wing Tail Type of Vtail, you would hook the Right Elevator servo to Rudder (Ch4) and the Left Elevator servo to Elevator (Ch3).
http://spektrumrc.com/ProdInfo/Files...nual-LoRes.pdf
Thanks BB for the help!
I imagine the CH6 (Aux1) is named as "FLAPS" in the Programmable Mix menu (p70)?
And I suppose the "slave" value for the spoilerons would be 100%, or would that be 100% for one and -100% for the other (to go up for both)? Not sure on that one.
ORIGINAL: vasek
I imagine the CH6 (Aux1) is named as ''FLAPS'' in the Programmable Mix menu (p70)?
And I suppose the ''slave'' value for the spoilerons would be 100%, or would that be 100% for one and -100% for the other (to go up for both)? Not sure on that one.
You will have to play around with the values in the Mixer until you achieve the correct movement.
BB,
I did the first two mixes OK. Now I have the V tail mix working and the ailerons slaved from ch2 to ch6 (with the mix switch always ON) working as normal ailerons should.
Now i'm lost on how to mix in another switch for the spoilerons to go up for both ailerons.
Can give me a hint what to do next?
ORIGINAL: vasek
BB,
BB,
You will probably need another mix setting the ailerons to just go up when you flip a switch.
Bush, I'm done with the setup, everything works A OK, except the RUDDER input is reversed!
BUT, since it is a V tail, reversing the RUD CH also reverses the ELEV input.
SO as it is now, I can either have the ELEV correct & the RUD reversed or the other way around[:@]
There must be a way out of this, just don't know how right now...
V.
V.
ORIGINAL: vasek
V.
V.
YES!!!! you're right as always[8D]s
I had them reversed by an oversight... Thanks again!
To be maidened this weekend [:@]
V.
V.
