New 6CH Radio....No response from Servos
WI
I just hooked up my Tower Hobbies 3000 6CH Radio and when I turn on the Tx and Rx I get no response from the servos. I did the recommended 15 hour charge. Any ideas? Is it a bad receiver? BAd battery? Bad crystal? I am pretty bummed since this weekend was going to be the maiden flight of my Avistar Thanks in advance.
Do the servos move at all when you turn on the rec? If not, could be a bad switch, rec or bat. Do you have the switch plugged into the rec in the right place? (had to ask) Are all the servos plugged in all the way? (again, had to ask) Is the transmitter showing that is has a charge on the meter? Is the crystal plugged into the rec all the way?
Those are just some of the main things that come to mind. If none of them work, you are going to have to send it back in. Sux to have problems like that. You may grab someone from the club to go over it with you before you send it in and see if there is something you missed. It is pretty straight forward though. Hard to miss. Probably bad switch or battery would be my most logical guess.
WI
Just call me Capt. Moron. It ended up being that the servo plugs are reversed. For some reason the servos plug in the opposite direction as the battery and of course there is no mention of that in the manual. Thanks everyone for the replies.
