Futaba FP-T8A-P
Futaba FP-T8A-P
I have a Futaba PCM FP-T8A-P 8 channel Transmitter / Receiver combination that has the FP-2FTM2-FM RF module for the Transmitter.
The set is 35.180 Mhz and I need to change it to a 29 Mhz type.
Is it possible to have the set modified for use as a 29MHz model? Apart from the two crystals, is there some work required in the Trans. Module.
Banned
RE: Futaba FP-T8A-P
The frequency difference would require retuning.
It is not known if the tuning range is possible with the components in use.
In any case it would have to be done by a certified shop witht he proper equipment to do this kind of work.
Suggest you contact the manufacturer or its distribution outlet and query.
Zor
Zor
RE: Futaba FP-T8A-P
ORIGINAL: Reilly4
