I Knew Better And Did It Anyway--IT GETS WORSE!!!
Reply
Old 08-09-2003, 04:20 PM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default I Knew Better And Did It Anyway--IT GETS WORSE!!!
Well I waited for the EVO as long as I could. I needed more mixing that the Cockpit could provide. Since I had owned a 8103 before and was familar with the programming, I broke down and got another with the FM receiver and installed it in my 84" WS Sukohi with the fiberglass fuse. Well at 30 feet it starts to glitch it's butt off-- this is with the engine off. With the engine running, I can stand next to it with the glitching WORSE! Now I can understand a bad ignition causing the problem with the engine running-- but a poor radio chaec new out of the box. I changed receivers with another NEW JR FM-- same thing!!!! I have since sold the Cockpit and stuck grounded. ANY IDEAS?? :stupid:
(knew I should had waited on the EVO)
AJF--2 is offline
Old 08-09-2003, 09:35 PM
HarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The first batch of Evos are now in the U.S.A.! They are being checked/made to U.S.A. spec or something like that, but they are on U.S. soil now. They may all be pre-sold, try contacting Karlton or Hitec USA to see if any are available and which day they will release them to sale. Quite a few people in Britain who couldn't wait and bought a Futaba 9C now wish they had waited, and I know one who traded back his 9C for an Evo. You have waited all this time, just hold on a little longer.
Harry
HarryC is offline
Old 08-10-2003, 02:05 AM
bob_nj
My Feedback: (62)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Harry, tell us a little more about the JR? Was it new, did you change crystals, was it damaged or dropped? Surely you know this is not a normal occurrence and something is wrong somewhere. Sometimes new doesn't mean perfect. Your EVO has as much chance of having a problem as the JR. When you changed receivers, what exactly did you do_bob
bob_nj is offline
Old 08-10-2003, 10:17 AM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No damage that I can tell. If it was dropped, it happened before I got it. I have not changed Xtals-- only receivers. I have bypassed the switch and unplugged each servo at a time. As far as changeing receivers, all you can do is unplug servos and plug them into the new receiver. They aer different models of receivers-- both FM. I do know this is not a normal-- but that does not make it less frustrating. When I get a chance, I got to test it on some different planes.
AJF--2 is offline
Old 08-10-2003, 12:41 PM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well after checking a few things, I found that I have 2 (yes, both of them new out of the box) bad receivers. My old Hitec Supremes are rock solid past 100 ft with the ant down. Now if I can just remember where I put those receipts..........
AJF--2 is offline
Old 08-11-2003, 06:48 PM
bob_nj
My Feedback: (62)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe the dealer has some paper trail of the transaction? JR has a great service department and a super warranty. Let me know what you come up with_bob
bob_nj is offline
Old 08-11-2003, 08:15 PM
3DFanatic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't be dissin' my 9C
3DFanatic is offline
Old 08-11-2003, 11:34 PM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well it is true. I switch receivers with a Hitec Supreme about 2 years old and everything is fine. Even with the engine running at 100 ft there is no jitter at all.
AJF--2 is offline
Old 08-18-2003, 12:46 AM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I installed 2 of the digitial servos (811s) in the wing of my Lazer 3 D funfly and took it out for the first time since switching the servos. Whil I am setting the throws they both start to go beserk!!!!! When you put your finger on the ailirons, they stop-- until you move the surface again-- then they dance like a Bob-N- Head doll-- Up and down like you would not believe. I can see a bad receiver (not that I excuse it but things do happen-even 2 of them). But now I have also got 2 bad servos out of a batch of 4 that came with the radio. My buddy John has the other 2 in another project. Seems I just cannot win.
AJF--2 is offline
Old 08-18-2003, 12:50 AM
Flyfalcons
Flyfalcons's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
811s apparently don't work with PPM receivers. Try a PCM receiver.
Flyfalcons is offline
Old 08-18-2003, 01:19 AM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ?????????
[ 811s apparently don't work with PPM receivers
I have used them before without problems..... Am I missing something??
AJF--2 is offline
Old 08-18-2003, 01:25 AM
Flyfalcons
Flyfalcons's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just talking with a flying buddy at the field who tried to use them with a PPM receiver and they didn't work, they called Horizon to find out that they are meant to be used with PCM.
Old 08-18-2003, 01:55 AM
MikeL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Horizon is selling 811s in their 8103 promo pack. That's got a PPM receiver, so I really doubt that is the problem.
There are some very specialized JR servos that require a PCM system, but those are usually found on heli tail rotors.
MikeL is offline
Old 08-18-2003, 02:06 AM
Flyfalcons
Flyfalcons's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll check with them again, but I was darn sure they had to get a PCM receiver to use their servos.
Old 08-18-2003, 06:39 AM
HarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All servos (except higher frame rate dedicated tail rotor gyro servos), use standard PPM data. PCM Rx have to convert the signal back to PPM for the servo outputs. There is no such thing as a PCM servo because no PCM Rx outputs PCM data.
Harry
HarryC is offline
Old 08-18-2003, 09:36 AM
Imac Kiwi
Imac Kiwi's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hear Hear Harry
I have a Raptor 30 full of DS 811 servos and they work just fine with an Airtronics 92777 FM Rx 72 mhz using a JR 3810 TX. Tail rotor servo is NES 8700G.
Just my experience with them.
Imac Kiwi is offline
Old 08-18-2003, 10:06 AM
HarryC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AJF - I believe that HitecUSA is shipping the Evo to USA shops this week, possibly even today.
H
HarryC is offline
Old 08-18-2003, 10:17 AM
AJF--2
My Feedback: (119)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default VERY FRUSTRATED
While at the field yesterday I heard that the first shipment is all gone and the second is 2 more months away. My buddies may have just been "jerking my chain" since they know this is a very sore subject with me. Tower is suppose to notify me when they are here and I have not heard a thing.
At any rate Mike is correct. The servos came with a PPM receiver in the package-- of course it is the one that didn't work- then again maybe that is the problem with the receiver since I was using MPX digitial servos. Hard to remember the reason for the post was 2 receivers not working. I have a hard time believing Horizion is dumb enough to sell a $400 radio system that they know won't work! (Of course you never know)
AJF--2 is offline
Old 08-18-2003, 07:26 PM
Dylwad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Re: VERY FRUSTRATED
the JR 549 ppm RX is not compatible with digital servos, thats why they include the r700 with the promo deal.
Dylwad is offline
Old 08-19-2003, 01:58 AM
Flyfalcons
Flyfalcons's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Re: Re: VERY FRUSTRATED
Thanks, that must be the receiver that my friend tried to use with the 811 servos. Glad I'm not going crazy (relatively speaking, of course)
Old 08-19-2003, 03:20 AM
Dylwad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From the horses mouth.. http://www.rcuniverse.com/showthread...4&pagenumber=2]
Dylwad is offline
Old 08-19-2003, 11:55 AM
blkbird68
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
...the signal to the servo is a PWM signal not PPM or PCM...
and as far as the JR rx's go 549's and 649's have problems with "noise" the 549 is worse than the 649...
a switching regulator can cause problems with either one of those Rx's and on the 549, digital servos even give it a fit..
blkbird68 is offline
