ARE CHOKE RINGS NEEDED WITH 2.4Ghz RADIOS
I'm building a plane that instructs the use of choke rings(servo extension wire wrapped in circles through a doughnut shaped ring) because of metal wing struts. These struts are metal and have metal pins that attach them to the fuse and wing. I know we used these with 72Mhz radio systems. Just curious if they are needed when using 2.4Ghz systems.
