FG8 Mixing problem
RE: FG8 Mixing problem
ORIGINAL: funflyerf4
I can not stop channel 3 and 6 from being mixed,I think it was mixed allready possably the in flight mixture adj? Any Ideas?
Frank
Frank
Try switching to an unused Model Memory, go to the System Menu and Reset the Model Memory to Factory Defaults, then do a minimal setup to see if the problem reoccurred. If not, move on to the next step and check again. If you have completed the setup and you do not have the problem, then you are home free.
You can use this method to debug any issue, then return to the problem Model Memory and make the change.
