Futaba servo hum
Futaba servo hum
Hi all, I installed a bunch of Futaba S3010 hi torque servos in a plane and there is a very noticable hum when they are turned on. There is no binding or anything like that.I know this isn't normal, your comments would be greatly appreciated.
1 Post
RE: Futaba servo hum
S3010's are not digital servos...
They are very analogue
Humming i suppose is normal if you are using a 6V or 6.6Vbattery pack. These are rated for 6V battery packs so not problem with that.
IF they were whistling I'd worry
ORIGINAL: Jezmo
Even analogs will hum a bit if the control surface is heavy enough to put a slight load on them.
ORIGINAL: Silent-AV8R
When they hum do you recognize the tune? [&:] Mine are all off key.
Just be happy it isn't 'Taps'.
