Receiver options
Receiver options
Hello all,
I am starting to realize why people call their living spaces "Hangars". My question is what are most people doing for recievers. Do you maintain a reciever for each plane or swap them out according to what flying mood you are in. If so what are good choices for recievers for park flyers and Light balsa 3D's. I have a DX7.
E.
E.
RE: Receiver options
Just got back from the old abondoned flying field. Bumped into I guy there who was able to answer my question. Due to the time it takes to set up wires and positions for proper C/G the easy way is to have a reciever for each plane.
New question. Do larger servos require larger recievers for more power or are recievers basic and you just are upgrading to more channels and functions.
E.
E.
ORIGINAL: GravityWorx
E.
E.
Larger servos, especially if they are Digital, will draw more current, requiring higher capacity Rx batteries. Most servos are rated for 4.8v or 6v, with 6v giving you faster speed and more torque. HV servos will allow you to use 2cell LiPo Rx battery packs, at fully charged voltage of 8.4v, and no voltage regulator required. You would need to look over the specs of the Rx you plan to use to determine what it's voltage limits are. I believe you will find that some of the smaller Rx's are voltage limited.
