servo question
Reply
Old 08-13-2003, 05:23 AM
suitcase
suitcase's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo question
Where do the little brass sleeve things go that come with the servos ? They wont fit over the pins on the servo trays. I can't figure out where they're supposed to be used.
suitcase is offline
Old 08-13-2003, 05:39 AM
SilverComet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You put the brass sleeves in the rubber mounts and slide them onto the mounts on your servos before you screw them into your servo tray. This allows vibration dampening by the rubber mounts while the brass sleeves protects the rubber from being cut by the screws in prolong vibration.
SilverComet is offline
Old 08-13-2003, 07:42 AM
lortap1969
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also try sliding the brass sleeve over a jewlers screwdriver and then use the this to push the sleeve into the rubber mounts. Will save time and frustration.
Mike
lortap1969 is offline
Old 08-13-2003, 05:39 PM
suitcase
suitcase's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know that I'm not explaining myself well enough. The servo tray has two pins on each end. The servo itself has two rubber mounts on each end that fit over the pins. If I insert the brass in the rubber mounts and try to slide it all over the pins it won't go because the pins are too large to accomodate the servo like that. I have to remove the brass sleeves and then it mounts easy. The keeper is a triangle shaped device with three holes. Two slide over the rubber and pins and the third accepts the mounting screw. Now are you saying that the mounting screw also gets a rubber washer installed using the sleeve?
suitcase is offline
Old 08-13-2003, 06:01 PM
SilverComet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That sounds like a pretty unconventional servo tray, do you have a pic of it and the keeper?
The rule is you always want to use the rubber mounts and never mount your servo TOO tight. If you are fitting the rubber mounts over wooden pins, unlike screws with sharp edges, and you feel that the pins won't cut the mounts under vibration, go for it. Just check your rubber mounts regularly to make sure they aren't cracking. You might also want to put rubber mounts on the mounting screws if you have extras.
Old 08-13-2003, 06:03 PM
T_Hill
T_Hill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You use the brass eyelets when you mount the servo directly to a servo rail without the tray. The eyelet keeps you from over tightening the screw. You don't need them on the tray you describe.
Silver comet,
The tray sounds like a futaba, that's what came with my 8U.
Tracy Hill
T_Hill is offline
Old 08-14-2003, 01:03 AM
mglavin
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tracy, nailed it. The Futaba trays do not require the brass eyelet.
mglavin is offline
