Spektrum binding issues
Okay, so my Tx and Rx got in today. However, they refuse to bind properly. The Receiver goes into bind mode, orange LED flashing away, but it doesn't go solid after a few seconds once I put the Tx into bind mode.
Tx: DX5e
Rx: AR6110e
Any ideas what's going on?
RE: Spektrum binding issues
If the reciever is fast flashing then make sure you're holding the transmitter atleast a few feet away from the receiver and you're not sitting on a metal work bench surface or the like.
I dont know what puts the 5 into bind mode but hold it for more than a "couple seconds"
I just read the owner's manual for the transmitter/receiver and it says the transmitter will make a tone sound when the system is bound. Don't know, I don't own one of these, but try the manual instructions again and see what happens.
ORIGINAL: 378
Tx: DX5e
Rx: AR6110e
Tx: DX5e
Rx: AR6110e
If you are Binding using the Bind Port on the receiver, be sure your Transmitter and Receiver batteries are properly charged.
Trying to Bind while next to a Large Metal Building, like an Aircraft Hangar, will prevent you from being able to Bind.
ORIGINAL: 378
I got it bound! Cause was weak Tx batteries. Guy before me was running some sort of cheapy chinese 99 cents for a pack of forty gas station AAs. I threw four Duracells in and it bound first try.
Thanks for the help guys!
ORIGINAL: airbusdrvr
And had it been able to get airborne before the batteries died, we could have had ''another Spektrum radio failure'' thread
ORIGINAL: 378
