Radio recommendations- upgrading
Hey, I want to upgrade my radio from a 4 channel to a 6channel n above. I don't want to spend too much though...
One of my friend recommend me to get a Futaba 9C radio, but it's really too expensive. I'm thinking of a Hitec Eclipse 7, that costs $450 here. The Futaba 6TAS cost about $440. My instructor uses a Hitec E7, i found it to be pretty good, but the Tx was really heavy and springs were looser than my Skysport 4. 6TAS is worse...the springs are sooooo loose. I want a E7, what do u think?
Any other recommendations?
My Feedback: (16)
Oh, I just check servo city. You can get a 9C set up for like $379.00. I'd buy that over the E-7. I love mine.
http://www.servocity.com/ServoCity/P...ol_units_.html
As far as PCM or PPM, flip a coin. PCM RX's will be more expensive. The buddy box works with either. Find who told you they don't and slap them
well actually, it really doesnt- my friend has a 6XAS, and he tried 2 buddy box with my Skysport 4 and it doesnt work.
A 9C costs like $770 here. A E7 costs $450.
Oops!
Wut are the advantages of PCM and wut is PPM???
Oops!
My Feedback: (16)
I have a feeling it was something other than the fact one was PCM and one was FM. But, hey, I've been wrong before! I have a 9C and can use my buddy box on either PCM or PPM.
The main difference between PCM and PPM (they are both FM signal transmissions) is that with PCM, you can set the plane's servos to go to a predetermined position. This way, if the signal is lost you know what the plane will do.
For example, you have it set to go to idle, a little up elevator and a little right aileron. Now, if you are inverted when it loses the signal, it doesn't really do what you might like. The throttle down feature is nice, though. That way you know it's not going to go full throttle into the ground or ??
With PPM, you have no idea what the servos will do. I've heard PCM is more resistant to getting hit.
Hope this is helping some.
CSISFUN.. go with the Hitec, its a fine radio and wil last ling, other option (if availabel in Singapore) is Airtronics, either RD6000 or RD 8000, they will work wiht Hitec receivers, but no buddy cord compatibility
For that much price difference choose the Hitec
My Feedback: (50)
howdy
Hawker means "Fail-safe"
PPM is just fine.... If you run ignition engines (big gassers!) the PCM is better because the gasser sometimes has a little interference-
Singapore is super expensive- A friend of mine does security for Microsoft and it costs her a fortune to live there-
$770 for the 9C- ouch!
keep us posted,
james
P.S. Hawker- gonna be at the weedwackers Sunday afternoon-
keep us posted,
james
Re: howdy
keep us posted,
james
keep us posted,
james
and why do u call FM PPM??? :S.
Indeed Singapore is home to expensive stuff... well maybe property, cars and RC planes... SIG ARF can costs up to $500!!! $528 for a 4* ARF!!!
Man... thats too much!
My Feedback: (16)
PCM has "fail safe". PPM does not.
Both PCM and PPM are FM signals. PCM is: pulse code modulation, PPM is: pulse, pulse modulation.
Again, they are both FM signals. I don't know the technical details on the difference between them.
