Servos for plane
NS, CANADA
Servos for plane
Im a newbie to rc and looking into getting a plane for a starter and was wondering if i need different servos for different functions or could i just get 4 of the same servo and it would control everything?
Im looking on buying the Hobbico Avistar 40 ARF from www.greathobbies.comfor 109.99 which i didnt think was a bad price for the plane itself compared to others ive seen but as I said im a bit of a newbie to this world and wasnt quite sure about the servos.Which somewhat inexpensive servos would be good for this plane?I dont have any hobby stores nearby(closest is a 4 hour drive) and am starting from scratch for everything and dont have a whole lot of money to begin with so im forced to buy most things one at a time.
Thanks for the help
Joey
Thanks for the help
Joey
RE: Servos for plane
ORIGINAL: bigjoe1986
Im looking on buying the Hobbico Avistar 40 ARF from www.greathobbies.com for 109.99 which i didnt think was a bad price for the plane itself compared to others ive seen but as I said im a bit of a newbie to this world and wasnt quite sure about the servos.Which somewhat inexpensive servos would be good for this plane?I dont have any hobby stores nearby(closest is a 4 hour drive) and am starting from scratch for everything and dont have a whole lot of money to begin with so im forced to buy most things one at a time.
Thanks for the help
Joey
Thanks for the help
Joey
http://www.greathobbies.com/producti...d_id=HITHS311S
The gears in the following servos will last longer:
http://www.greathobbies.com/producti...d_id=HITHS322S
The Ball Bearings on the Output Shaft, for the following servos, will help keep the the Output Shaft in line longer:
http://www.greathobbies.com/producti...d_id=HITHS325S
Take your pick, but I would vote for the 3rd choice.
You can look at similar servos from other manufacturers, as well. Hobby King has some really cheap servos:
http://www.hobbyking.com/hobbyking/s..._31_2D49g.html
Check out Servo City:
http://servocity.com/html/hitec_servos.html
If you are like you said a newbie and starting from scratch, when you decide to buy your radio system it is usually supplied with 4 standard type servos which will be quite suitable for the model you have selected.
Karol
Karol
Thanks for the help
Joey
Thanks for the help
Joey
You will need to purchase Fuel, Fuel Pump, a Glow Stick, Electric Starter + Battery(you could use a Chicken Stick as a substitute).
For a newbie just getting his foot wet in this hobby it would be a great help if you got associated with a club or an experienced flier who would be able to assist you in getting started. Also read everything you can find on flying RC models
Karol
Karol
